Volks AutosSky Insurance
Results 1 to 8 of 8
    Mar 2013
    Belfast
    23
    Not the normal LCD problem
    I have done a search and seems most peoples lcd dis problems are pixel problems... Mine is completely blank, with no red back lighting.
    Its not off on the reset button, tried this.
    In addition to this i have no fuel light and no auto checks upon switching on, so seems the display is powerless or all bulbs have gone which i think is unlikely.
    I have removed and checked fuses 5, 12 and 15, all are fine and seem good and tight in their slot
    Anyone had this problem or know any fixes?
    Thanks in advance for any help... ps its a November 1998 tdi se
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Re: Not the normal LCD problem
    Missing pixels is down to a connection issue on the board.
    The same sort thing happened to mine.
    It could have completely lost connection.
    You could attempt a DIY fix or send away for repair.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Mar 2013
    Belfast
    23
    Is it worth removing cluster then and looking for a wiring issue behind it? What sort of places repair this type of thing, not a normal autospark is it?
    cheers
    Jul 2012
    Guildford
    97
    Quote Originally Posted by ScottB5 View Post
    Its normally the screen delaminating rather than a connection issue. I put a new screen in myself and was a real PITA. If its not lighting up at all then its probably the bulb or the posative feed to a number of bulbs if you have a few out.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,375
    If the backlight is off, its not an LCD issue... The backlight is totally seperate...
    TD5 Land Rover Defender build
    Mar 2013
    Belfast
    23
    Thats what i thought, it's 100% dead. Do you know how to sort the backlight issue?
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Are you totally sure it's not just turned off?
    2000 1.8t quattro Sport totally standard (ish)
    Mar 2013
    Belfast
    23
    Yeah ive tapped the stslk button, held it and played about. Surely you aren't able to turn the fuel gauge off and it would override it being off?
  1. Temperature Gauge Problems / Fan Codes / Cluster and not the normal fix!
    By TimCrighton in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th August 2012, 10:01
  2. Not the normal clutch question.
    By brough74 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th April 2011, 12:58
  3. S3 Alarm Problem, but not the batteries!
    By silver_mase in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th June 2010, 17:24
  4. Ticking noise from engine (not the normal one)
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th November 2008, 22:40
  5. Seat Problem............. :o( (ps seat as in seat, not the car make)
    By imported_Wicked666 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2005, 09:38
