Chris NottJMB Retrofits
Results 1 to 13 of 13
    Feb 2013
    huntingdon cambridgeshire uk
    42
    1999 fwd front wheel bearing
    think ive got a front drivers side wheel bearing on its way out got a lancaster aeroplane noise going on about 40-60mph and when i go round left hand bend so that side is loaded right up its goes quieter do the bearings need pressing in/out etc ?or anybody got a guide to doing job ?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    yes bearings require a press or similar.
    Before you take it apart, spin each wheel with the car jacked up, the faulty one will sound rough.
    TD5 Land Rover Defender build
    Feb 2013
    42
    ok will jack it up in a moment on other cars ive used old sockets etc and studding and nuts to draw bearings in and out is this trick doable with these bearings ?
    "Stick a V8 in it!"
    15,388
    Possibly, but the Audi bearings have no circlips and are a very tight interference fit. Some can need 5+ tonnes of pressure to shift the old bearing, and most i've done seem to need a couple of tonnes to press them back in.
    Feb 2013
    42
    just checked both front wheels no play no noise i put a new track rod end on recently and know tracking is out im due two tyres and tracking in couple of weeks is it possible its tyre noise as front right tyre is one that is out on tracking ?
    "Stick a V8 in it!"
    15,388
    check the rears as well?
    It wont be loud, it'll just have a slight rumble to it.
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    617
    I managed to change the (similar-looking) front bearings many years ago on my Series 4 Audi 80 with a couple of drifts and a very big hammer,lol, but when I did the same job on my present A4 I used a hydraulic press, as Aragorn says they are a very tight interference fit.
    Getting the old ones out and new ones in took almost 5 tonnes of pressure as stated, there's no way IMHO you'd do it without hydraulic assistance.
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
    Feb 2013
    42
    ill jack up again tomorrow but all i could hear spinning front wheels was slight drag of brake pads as normal
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    617
    When I did the fronts as mentioned above there wasn't a lot of give/feel evident in the bearings until I was able to press them out of the hubs.
    When they were removed they appeared very very rough and most definitely clapped-out....
    Feb 2013
    42
    nessy think that what wrong with mine cant feel anything but its def noisy from drivers side
    Feb 2013
    42
    been under again and found split boot on cv and over last couple of weeks get a small clonk on taking drive up could this also be my prob at speed when running aswell a worn cv joint ?
    Aug 2011
    199
    FWIW I had the "drone" of a dud bearing a few months ago and couldn't diagnose which side it was by "spinning the wheels" - even the garage couldn't be 100% sure which side it was and it didn't make any real difference whether it was loaded left or right. Mike
    Feb 2013
    42
    mike did you have both changed in the end ?
  1. front wheel bearing 2.0 tdi part number??
    By kaos in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd September 2011, 23:53
  2. Front wheel bearings .....a warning.....
    By Nessy in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th May 2011, 19:31
  3. Anyone had a new front wheel bearing fitted on their A3?
    By RobinA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th March 2010, 18:38
  4. Front Wheel Bearing/Hub Assembly
    By gavinsky23 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th February 2010, 18:40
  5. DIY S3 Front wheel bearing....
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th December 2009, 21:32
