Volks AutosEM Tuning
    Mar 2013
    24
    Quattro abs module repair
    Looking to repair the module tomorrow on my tqs, by hopefully soldering the two silver wires back on the contact patch,
    presuming these wires are the culprit, looking at the tutorials, it seems asif there is just one blob of solder of both of the wires onto the contact patch, is this ok?
    Also, what is the purpose of soldering a copper wire between the 2 wires?
    cheers, jay
    Jan 2011
    Aberdeenshire
    646
    I had a go at this a while back - I did a thread somewhere - ABS Module repair - found it.
    If you are reasonably competent with a soldering iron it shouldn't be too hard. In my thread you'll see I failed - bit that was finger trouble!
    You will need a reasonable iron, and some flux to clean the pads.
    The reason for soldering on the copper link is the originals are brittle and prone to snapping. The replacement copper link will outlast the module
    Also bear in mind that once you have cleared all the codes, you may have to drive a short distance before the light goes out.
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    Mar 2013
    24
    so you soler a copper wire between the two silver wires and then solder that to the contact pad?
  1. ABS Module repair
    By PAULF in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th June 2012, 12:12
  2. Brake pedal pulsating after installing repaired ABS module
    By PelicanBlue in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd May 2012, 09:09
  3. A4 Quattro 1997 ABS Module Problems?
    By Luke Bowe in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th October 2011, 15:25
  4. ABS modulator
    By jayne in forum Classic Audi Forum
    Last Post: 13th September 2007, 18:10
  5. trying to get airbag module repaired
    By dubmas in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th September 2007, 20:23
