EM TuningVolks Autos
Thread: ECU help!
    B5QUAT's Avatar
    Apr 2011
    The North
    298
    ECU help!
    Just took the ECU out of the car to remove the aftermarket chip fitted. Plugged the old OEM chip back into the chip socket soldered on the board by the chipper and put it back in the car.
    Car now turns over but won't fire.
    Gonna try puttin the uprated chip back in and see if it runs again.
    Any ideas what I could have done wrong????
    Chip is in the right way, might it have got damaged somehow while out of the car?
    Any pointers in the right direction very much appreciated.
    1999 B5 k04'd S4. Eibach coilovers, RS6 front brakes, RS4 Rears.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,889
    Check for any obvious signs of bent/crushed pins on ecu and chip make sure its DEFINATELY in the right way other than that i wouldnt of thought disconnecting it would harm anything so long as you didnt have the ignition on when disconnecting it, have you got vagcom ??? If no joy im in oldham 2moz and could try get over with laptop if needs be.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Aug 2010
    2,889
    Any joy pal ??
    B5QUAT's Avatar
    Apr 2011
    The North
    298
    Quote Originally Posted by Bradderz_1988 View Post
    Any joy pal ??
    The weather put me of yesterday and it's not much better today. I'll whip it back out when I get chance an have a proper look. Pretty sure all the pins were ok and it's definately in the right way. I'll double check the pins tho and let you kno. I even took the battery negative terminal off to disconnect and reconnect. I'll see if I can work it out and put the uprated chip back. If not we can always have a look at it on the 1st when we do the exhaust. I've not got vagcom, no so if you could bring it, that would be great. cheers.
    Aug 2010
    2,889
    Not a problem pal il make sure its charged up for the 1st just incase.
  1. ECU Help Needed Were To Go 2003 8L TDI
    By Audi-Power in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st March 2012, 16:04
  2. How to Reset my ECU Help Required and some VCDS Help
    By sohail579 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th August 2011, 13:04
  3. Anyone know where to get a decent second hand ECU? - HELP
    By geordiea3 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th April 2011, 14:54
  4. water in ecu , help please
    By kninio in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th August 2007, 16:55
  5. Need new ECU - Help!
    By andyjg in forum Diesel forum
    Last Post: 28th May 2007, 22:19
