EM TuningVolks Autos
Results 1 to 15 of 15
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,879
    Cheap as chips !!
    Well as we all are doing little bits and bobs of modding every now and again i though it would be good if we had a 'cheap' mods thread were we can post our little upgrades up they cant be 'steal' upgrades but ones that are sub £100 and are relatively priced parts used or new.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    TrisLC's Avatar
    Feb 2013
    Cheshire
    333
    Metal pressed plates for £40 delivered, look so much better than standard plastic plates!
    B5 1.8T Quattro
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,933
    Twin rear foglight upgrade on facelift tail lights.
    Remove n/s light cluster (4x 8mm bolts) use Dremel or stanley knife to open bulb recess in back of cluster. Fit 21w bulb and trial fit bulb holder and trim further if required. Refit unit to car, plug in light harness and check.
    Cost: £2 for bulb
    Life begins at 140mph
    www.passionford.com
    Aug 2010
    2,879
    Yeah pressed plates is a good one it was one of the first i did along with audi sport plate holders !!
    hmm twin rear fog i may do that one but then again i hadly uses my rear fogs but i guess it would be useful if i ever did uses them lol
    TrisLC's Avatar
    Feb 2013
    Cheshire
    333
    Silver indicator bulbs, from 5 to 20 quid depending on manufacturer.
    B5 1.8T Quattro
    TrisLC's Avatar
    Feb 2013
    Cheshire
    333
    Quote Originally Posted by Bradderz_1988 View Post
    I have just stuck some on mine tbh great upgrade for a vag car. Ive not gone for holders though couldn't make my kind up to weather i like them.
    Ive kept the audi ones ive just removed so could put them on if i change my mind lol
    B5 1.8T Quattro
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    388
    Quote Originally Posted by TrisLC View Post
    Ebay pressed plates, £24 delivered!!!! Had Dubmeister ones on my golf but bought these for the Audi, quality is just as good but cheaper
    Pressed Metal GB number plates 100% ROAD LEGAL | eBay
    griswold's Avatar
    336
    A4 1.8T Quattro sport
    A6 2.4 Avant SE
    Aug 2010
    2,879
    Quote Originally Posted by ajax1976 View Post
    yep there the ones i have and are spot on for £24
    TrisLC's Avatar
    Feb 2013
    Cheshire
    333
    Always used dubmiester and had no issues, but would have prefered to pay £24 lol Ill remember that for next time
    B5 1.8T Quattro
    Andyb5's Avatar
    Nov 2012
    62
    good thread
    couldn't resist a set of these plates, just ordered my ones off ebay :-)
    Oct 2012
    388
    This is a free mod, when you can't take the rain scuttle off round the bottom of the windscreen coz some numb head in the past has chewed the plastic heads, heat up a large flat blade screwdriver (heat source is your choice) and stick it in the plastic heads to make a lovely slot, clean off burnt plastic with sharp knife, for asthetics it's best to do both sides!
    Jan 2013
    59
    Magnetax tax disc holder is a nice cheap way to clean up the windscreen from awful ugly big tax disc holders.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,678
    Re: Cheap as chips !!
    A HID kit via the group buy. :thumsbup:
    LED conversion.
    Porsche oil/coolant caps.
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    614
    I've just fitted a £2.95 (delivered) EGR valve blanking plate to my TDI.
    Its relatively thin stainless steel (more like a gasket really) and I've put it on the outlet flange of the exhaust manifold underneath the existing flexy pipe leading up to the EGR valve assembly.
    It doesn't look as if any mod has been done at all.
    There's no longer plumes of black smoke when I give it some welly, the low-down pickup has been transformed and I can't believe the difference it has made.
    Wish I'd known about it (and done it) ages ago!
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
  1. Cheap as chips
    By Bradderz_1988 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th April 2011, 12:16
  2. cheap chip/remaP
    By trekbiker in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th April 2005, 21:56
  3. To Chip..
    By A4Steve in forum General Technical / How To
    Last Post: 13th March 2003, 21:49
  4. PS2 Chipped
    By finster in forum Video Gaming
    Last Post: 12th February 2003, 23:18
  5. Chipping the Donkey!
    By gtdog in forum Diesel forum
    Last Post: 26th January 2003, 18:23
