    imported_ZeroK66
    30v v6 2.8 Owners lend me your \"ears\" - Cold startup noise
    Hello all,
    Well I have posted about this before... since my 80k service (Belts changed) the car makes a rattling/vibrating noise - heavy metallic kinda noise - like you would get if you were to spind a dry pully with play in it.
    Its only for a split second then clears. For the rest of the day it is then fine.
    I have now been to 3 dealers about it, the third one has said - this is normal and to be expected of the v6 engine from cold start and is the chain in the engine doing this. [img]/ubbthreads/images/graemlins/swear.gif[/img]... but wanted to hear your thoughts on cold morning start ups. Does your baby start up smooth and purr straight away?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Re: 30v v6 2.8 Owners lend me your \"ears\" - Cold startup noise
    Mine's a V6 30-valver, same as yours. It's also done 75K miles. It rattles for a second or two on start-up, then settles into a smooth idle. It's normal. It's just the surfaces rattling for a moment before the oil is pumping all the way round.
