Badger5Monster Motorsport
    Jan 2013
    27
    Running Problems with 1.8T
    hi guys i have a problem with my 1.8 turbo i have just put porformance plus in and k and n oil filter. Them i put tesco 99 % octane fuel and it just died and would take ages turning it over to start is it running to rich its had a stage1 remap1? Any ides to help me cheers
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    It's died since firtting th filter? iI'd bet the maf has given up due the oil from the filter. unless the fuel was full of water I cannot see that being an issue. It's all just an unhappy coincedence.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    I think hes put performance spark plugs and k&n oil filter on not an air filter ??? Stick to ngk bkr6e's i use k&n oil filters on every filter change never had problems with them, id check your fuel make sure you havent mistakenly put diesel in ive never done it but tends to be the case if it dies after fuelling if you got a receipt double check it as diesel will settle below the petrol in the tank, or as byzan said the maf is probably bust and its just utter coincidence check your plugs are tight aswel and not come loose as it will loose compression !!
    Mar 2013
    N/E Scotland
    7
    Good luck getting diesel in a petrol car, The pump nozzle is too big to fit in most cars!
    if you suspect the MAF, Disconnect it and try to start the car, the ECU will revert to a predetermined value and let you condem it or rule it out! Failing that you are back to basic checks, compression, fuel and spark!
    but like bradders says, Stick to the NGK plugs!
  1. Help with a running problem on boost please
    By S£ in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2011, 17:31
  2. Problems with 2.0 tdi running rough when cold
    By Pedro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th November 2009, 17:25
  3. Problems with Revo
    By RSAudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th August 2003, 13:48
  4. Problem with alarm
    By tim in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2003, 12:58
  5. Problems with alarm transmitter.
    By DJG in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2003, 08:23
