AH FabricationsVolks Autos
    Nov 2003
    114
    HELP!!tdi A4, throttle not working,
    throttle is doing nothing, and after ticking over the heater light flashes and the throttle tickover goes from 800rpm to 1200rpm, for no reason?
    any idea?
    faulty throttle pedal maybe?
    Nov 2003
    114
    Re: HELP!!tdi A4, throttle not working,
    Throttle Position Sensor seems to be a prob on tdi i see on other forums
    mikeA2B's Avatar
    Aug 2004
    NW UK
    385
    Yes my new shape Transit had the same problem, glow plug light flash and tickover only.
    Turned out to be the pedal.
    If you can you might be best to use vag-com just to double check.
    HTH
    Mike
    Nov 2003
    114
    aye sorted, water in the plug in the bulk head, below when the ecu box is.
