Chris NottSky Insurance
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Tracking settings
    Morning all
    I've a pair of trackrod ends to fit on Saturday to the tqs and was hoping someone here would have the ideal tracking settings that I can give to whoever I can find to set it on a Saturday which will probably be Kwikfit or ATS (only ones I can find on a weekend).
    I've never heard much good said about these places so if I can give them the correct figures there shouldn't be a problem (hopefully)
    Si.
    2000 1.8t quattro Sport totally standard (ish)
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,317
    My local kwikfit has a full hunter laser alignment setup, and while they're likely morons, i'm sure the equipment is good enough to keep them right.
    The system will tell them to dial in a small amount of toe in, but the handling feels better if you choose a touch of toe out. i went with 7minutes toe out on the avant when i had it done.
    TD5 Land Rover Defender build
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    All sorted. Went to Kwikfit in Bolton to find they had just taken delivery of a Hunter last week. I only wanted the tracking done but the guy was still learning the equipment so did me a full 4 wheel job (rear camber was well off) for £40. Bargain!!
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,113
    Nice score on the tracking our gauges at work are supertracker laser alignment with flags for the rears which is crap in my eyes when i worked at peugeot we had the 4 wheel computer jobbie which was a doddle now i have to fart around with them 2 or 3 times to get the car tracking straight (well, almost perfect) which kwik fit you go cant think if ive seen it on my travels through bolton as that can be my local new tracking place wouldnt mind paying to get it done with the proper tool for the job ours is out dated and ****e lol
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    It's the one next to Central Tyres near B&Q and the Merc dealers. 2 Howard Street Bolton BL1 8HS
    Aug 2010
    3,113
    Nice one pal
  1. ok my car's low but a set of track rod ends in a month???
    By nwmlarge in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2011, 13:12
  2. tt pedal set part numbers
    By ooooaudi in forum General Technical / How To
    Last Post: 9th April 2003, 20:16
  3. Donnington Track Day
    By Joshie in forum Major UK Events
    Last Post: 27th February 2003, 19:07
  4. Tracking Systems
    By Jack829 in forum General Technical / How To
    Last Post: 20th February 2003, 11:54
  5. Donnington Track days
    By Simon in forum Other Brands & Models
    Last Post: 13th January 2003, 15:56
