Sky InsuranceVolks Autos
    Feb 2013
    Bucks
    14
    1.8 t remap. & thermostat location
    hi guys, 2 questions:
    1. is it possible/ worth a remap for economy on a 1.8t if so how much should it cost?
    2. can someone point me in the right direction of the thermostat, as my heating dosnt get very warm
    cheers
    Oct 2012
    385
    If i were looking for a remap i would use MRC, all depends on where you are in the country. Thermostat location is underneath the inlet manifold, bit of twat to get to as you have to remove a load of bits to gain access, still not the worst job in the world to do
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    I wouldn't use MRC, they are not so good on 1.8t's, either Badge5 or Rtech are at the forfront of 20vt tuning atm.
    Stat is located in the plastic housing secured with 2 x 10mm headed bolts on the end of the rad lower pipe, dead easy from underneath
  1. remap problems lambda location
    By bigjim in forum General Technical / How To
    Last Post: 21st May 2008, 14:26
  2. 2.5 v6 TDI thermostat location
    By sprinter1801 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th April 2008, 03:50
  3. Thermostat location 1.8T?
    By JayB5UK in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th October 2007, 15:31
  4. thermostat location?
    By Rob_k in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th July 2007, 13:31
  5. Thermostat location? anyone? A4 TDI
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd February 2007, 10:09
