...but expect increased noise, fluid overheating and disc wear. I got the discs lathed on the hub also, which compensates for heat stress on the disc from previous use. If you want to get maximum life and performance from your new pads you must either change the discs or lathe them, my experience of s4 oem rotors is they will warp badly no matter what you do to them and i cannot find a replacement in the UK.
