Chris NottEM Tuning
Results 1 to 10 of 10
    205man's Avatar
    May 2006
    worcestershire, uk
    1,014
    how to remove seized rounded allen bolt?
    as some you know my water pump gave up, so my mate came round to help me pull car apart but we hit a snag.
    we cant get the idle pulley/bracket off, because the bottom allen key bolt is completely round inside and pretty sized, and the one above seem to be also seized but the head seems ok i just need better allen socket before i risk the head on that going.
    so an ideas on how to remove rounded allen bolt, ive seen load of ideas on the net, but thought id ask what has worked for you.
    the strange thing is the last time this was taken apart was 4 years ago when main dealer fitted new cam belt etc ???????
    cheers
    Jan 2011
    northants
    165
    i use irwin extractors
    they cut into the outer part of the bolt and work very well
    54
    Irwin extractors or hammer in a Torx or XZN bit.
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    +1 for the Irwin Bolt Grips. Excellent bit of kit!
    Mo power, mo problems
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,355
    xzn and a hammer here, not failed yet.
    Jun 2012
    148
    Hammer in a Torx
    Jan 2011
    Aberdeenshire
    628
    +1 for the Torx bit, or I have a stud remover that sometimes works, or pipe stilsons.
    1999 A4 B5 1.9 TDi FWD Saloon, Green
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine)
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,904
    Or weld on a standard bolt.
    TD5 Land Rover Defender build
    Aug 2009
    Stoke on Trent
    114
    I used an angle grinder to make a standard socket fit on... came off a treat and replaced the bold.
    That was on the rear caliper carrier bolt
    If i told you i have to kill you, but i could give you a clue and just rough you up a bit!
    ctd
    Oct 2012
    Plymouth
    105
    torx bit for me every time
  1. How to remove rounded screw, number plate light?
    By Ben S3 8P3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th November 2012, 21:13
  2. Advice on how to remove the top control arm pinch bolt..
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th May 2006, 19:06
  3. How to remove A-pilars?
    By kazino21 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2005, 18:15
  4. how to remove side light bulbs?
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th December 2004, 13:04
  5. How to remove black marker pen from paintwork?
    By imported_lewiscsfb in forum Detailing
    Last Post: 20th November 2004, 21:07
