Chris NottEM Tuning
Results 1 to 13 of 13
    Mar 2013
    6
    White smoke and oil in water AUDI A4 1.8 TURBO
    Hi lads ive got a 1997 audi a4 1.8t sport and ive noticed oil in the water tank and white smoke from the tailpipe when i accelerate. I believe this to be signs of headgasket failure but the car itself runs sweet as a nut with no overheating. The smoke from the tailpipe as no smell so im thinking its not oil from the turbo but water/coolant getting there. Whats your advice on the best thing to do to find the problem. cheers
    Oct 2012
    425
    could be the oil cooler, the oil and coolant run through a heat exchanger common problem, any mayonaisse on the oil filler cap
    TrisLC's Avatar
    Feb 2013
    Cheshire
    333
    I woulld have a sniff test done TBH, depends weather you know any good garages who will help you out?
    Ive had a car that showed signs of oil in the coolant, but there were no other signs. Had a sniff test done and it came back clear. Maybe worth flushing the coolant if its not been done for a while?
    B5 1.8T Quattro
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,109
    Id put my money on the oil cooler !!
    Mar 2013
    6
    Quote Originally Posted by Ian2012 View Post
    No mate nothing on oil filler cap just black oil its only in the water tank. cheers
    Mar 2013
    6
    Quote Originally Posted by TrisLC View Post
    ive already flushed the system yesterday mate. cheers
    Mar 2013
    6
    [QUOTE=Bradderz_1988;1818558]Id put my money on the oil cooler !![/QUO
    I am thinking same mate after what ive been reading, is there a way to test it without an hose it does look pretty easy to remove. cheers
    Oct 2012
    425
    don't think so
    Aug 2010
    3,109
    Yeah its a doddle to change just remove the coolant header tank 3 screws then uncouple the pipes and remove oil filter then the thin nut and slide the cooler off you should be able to test it by either running water through if any comes out where the filter housing/filter would sit its goosed or even blank the coolant ports of and leave it in water if when you take it out theres water in where you blanked off its goosed !!
    you can pick them up cheap and for the price compared to a headset inc labour its a no brainer as its a DIY job that takes 30 minutes and some time flushing out the cooling system.
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,641
    Mine did the same, turned out the oil cooler had failed... *phew*
    Currently rolling in a SKODA!!!
    Mar 2013
    6
    Thanks for all the info lads, if it is the oil cooler can i just change the O ring (seal) in the oil cooler or do you have to buy a new cooler. cheers
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,306
    The coolers fubar, you need a new one.
    TD5 Land Rover Defender build
    Oct 2012
    425
    +1 on that
  1. white smoke burning oil ?
    By bez101 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd January 2014, 21:14
  2. White smoke and plenty of it!
    By tyson in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd December 2012, 08:54
  3. TDI 170 mostly white smoke and bit of blue at idle, clears when revved
    By swanbon in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th October 2012, 13:22
  4. Clouds of white smoke and misfire
    By raffhussain in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 27th July 2012, 12:25
  5. Help! 56 TDI 170 - White Smoke and Loss of Power
    By SCFC_Messiah in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th May 2012, 15:19
