Volks AutosEM Tuning
Results 1 to 8 of 8
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Exhaust question
    As i will be getting my hands on a full milltek system at some point this month i want to now the diameter of the standard TQS exhaust system as i need to order some new clamps for the downpipe and the back box ??
    i think i asked this question a while ago but i cant seem to find it is it 2.25" ????
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    stock system is 2.25" or 57mm
    If your fitting a milltek system its larger afaik?
    TD5 Land Rover Defender build
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,752
    I am sure I read the miltek is 2.75"
    A4 1.8T Quattro
    Aug 2010
    3,138
    Ye the milltek is 2.75 but im gunna order some for my system do that when i do the swap there will be all new clamps and gaskets on the car the milltek is coming off.
    "Stick a V8 in it!"
    15,388
    ah k
    The stock system is one piece, so you should only need the clamp at the downpipe unless the backbox has been replaced at some point.
    Aug 2010
    3,138
    Theres a clamp at the rear so suspect its been replaced at some point.
    "Stick a V8 in it!"
    15,388
    best measure it, ETKA says some systems are 55mm and some are 60mm at the joint between boxes...
    Aug 2010
    3,138
    I might aswel just order both size clamps and just have parts at work send the wrong one back rather than going under the car !!
  1. Rear Exhaust question
    By mattv6 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th November 2008, 14:14
  2. S4 Exhaust Question..........
    By MJL in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th February 2008, 18:48
  3. Miltek Exhaust Question
    By ash_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2007, 20:25
  4. Replies: 0
    Last Post: 18th November 2004, 17:54
  5. Exhaust question...Don't you hate me?
    By HotSauce in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th July 2004, 06:54
