AH FabricationsSky Insurance
Results 1 to 10 of 10
    Mar 2013
    16
    98 a4 2.8 running on 3cylinders?
    So here's the deal, I Bought this car around 8months ago with a bad timing belt. Long story short I rebuilt the heads everything's all hooked up I'm getting spark and fuel to all six cylinders. I started it with no serp belt on and the battery is pretty so so. But still decent enough to start it. It idles pretty descent revs super slow. Ran it for about thirty seconds then felt the passenger side manifold it was warm. The drivers side was cold. Now what's really got me confused is that the car is auto with tip, when I turn the key to the on position it says press clutch before starting. When I first got the car it never said that..so I'm wondering if the ecm is bad? Any input would be great because I'm beyond stumped!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,384
    it wouldnt idle decent on 3 cylinders... i had craigs S4 running on 5 when i forgot to plug an injector in, and it sounded like absolute ****!
    TD5 Land Rover Defender build
    May 2010
    194
    Check the order of the ht leads.
    During my recent ordeals I achieved a similar state of running at one point.
    Two leads out of order can cause those exact symptoms.
    Mar 2013
    16
    Ht leads? Bear with me I'm somewhat new with this stuff. I understand it wouldn't idle on 3 but it's what it seems like. I pulled the fuel rail off and had someone hit the key all six injectors are working
    May 2010
    194
    HT leads = spark plug leads = ignition leads.
    Likely to be the front two that are swapped around on the cold side of the engine.
    Mar 2013
    16
    Oh I checked the firing order multiple times it is correct according to my chiltons manual it's getting spark on all 6 yet when it's running the drivers side exhaust manifold is ice Cold and passenger side is warm. There is no exhaust hooked up yet it is running off headers. Didn't want to get too carried away on putting it together if it wasn't going to run descent
    May 2010
    194
    OK, but it won't hurt to check again.. or even just swap them over and try it. Mine was correct according to some sources as well.. shame those sources were wrong.
    But I can't force you to try it.
    Mar 2013
    16
    I'll give it a shot when I get out of Work I hope that's the issue!
    Mar 2013
    16
    Well you were right. The darn book was wrong had two plug wires backwards now runs like a champ! Thanks a lot guys. Oh and as far as the dash saying press clutch before starting even though it's auto has stopped and went back to normal. Not sure why it was doing that but whatever it runs!!!
    May 2010
    194
    Quote Originally Posted by sternybaby212 View Post
    Good. I won't tell you the stress and wasted time that one gave me.
    I'm glad my grief has helped someone out of the same predicament.
  1. Running in a new 1.8T
    By a900ss in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th April 2004, 11:59
  2. Rough Running Audi 80
    By DONK in forum Classic Audi Forum
    Last Post: 4th March 2004, 11:48
  3. More running probs with Kitty
    By audi_girl in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2003, 08:30
  4. My lumpy GTI, running lumpy, any ideas?
    By Dr_Lokos in forum General Chat
    Last Post: 26th August 2003, 22:32
  5. The old chestnut of running in..
    By noodle in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2003, 10:58
