Results 1 to 10 of 10
    TDi Powerrrr
    Aug 2010
    North Devon
    404
    Front Seat Removal?
    hi,how do you remove the front seats from a 2wd facelift?
    Also,has anyone got a pic of the inderside of a standard seat?
    thanks
    tony
    Jun 2003
    World of my own
    9,813
    You just remove the 2 plastic stops at the back of the runners, remove the stop from the front adjuster (pinch it together and pull out) then slide the seat backwards until the rear runners are clear and lift out
    Alex Turner
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,742
    Look in the rear footwell and at the end of each runner there is a plastic trim which is held on with one screw. Take these off. Then look under the front of the seat and you will see a silver pin in the middle of the seat. Pull that out. Then disconnect the airbag connectors and slide the seat right back and it will slip out the runners.
    A4 1.8T Quattro
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,956
    Re: Front Seat Removal?
    Like above but it can get stuck on carpet and make it a pain to remove.
    So you might have to push the carpet down while you play with the seat.
    What pics are you after?
    I stripped my seats down and posted pics some where.
    I'm not at a PC so can't find them for you that easy at the most.
    What B5s had bolt down seats?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    TDi Powerrrr
    Aug 2010
    North Devon
    404
    thanks for replies
    Scott,am hoping you can remove the subframes from the oem seats,so I can weld/bolt them to my new seats
    tony
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,956
    Quote Originally Posted by tonya4 View Post
    thanks for replies
    tony
    The base of the seat is welded.
    To take it off you need to cut the welds.
    Foxmister did what you want too do. Its in his build thread.
    TDi Powerrrr
    Aug 2010
    North Devon
    404
    thanks Scott,will have a look
    also,got my spare grill,ready to be dipped
    tony
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Yep, as Scott says i stripped mine for some custom seats, but due to my fixings being a bit awkward, and i found a supplier of proper bases to work, i bought a set made for fitting aftermarket Recaros etc. It would have worked still doing them custom like i had intended, but once you line up seats with the B5 bases, you see how little weld you will achieve mating them to another seat, and as i will have family/friends in the car and maybe do some track time, i decided the better option was the manufactured design i went with in the end.
    What seats is it your attempting to fit?
    Project RS28 build
    TDi Powerrrr
    Aug 2010
    North Devon
    404
    thanks for the reply foxy,would rather not say what the seats are yet though!
    I got my seats out my breaker earlier,and see what you mean about how little there is to weld to!
    Where did you get your subframes from?
    tony
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    tony
    PM'd
    Project RS28 build
  1. Still chasing a front left knocking / squeeking - also front seat removal
    By Squirrelofdoom in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th September 2012, 14:44
  2. A3 1.8 Sport Yr 2000 - Front Seats Removal Advice
    By mguilfoyle in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th April 2012, 22:56
  3. How to remove the Front Seats? Any Body?
    By Offtrack4Speed in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2007, 18:54
  4. Help removing oil/grease from front seats
    By technics100 in forum Detailing
    Last Post: 3rd April 2006, 21:23
  5. removing front seats
    By Dean_T in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th May 2005, 00:04
