Chris NottJMB Retrofits
Results 1 to 9 of 9
    Aug 2009
    Stoke on Trent
    114
    Inside the Rear Caliper of a B5 A4
    The information i wanted with pics about the rear calipers and handbrake assembly was very limited so went into this somewhat blind.. other than seeing a great writeup of a B6 rear caliper setup... so thought i would just post a few pics here so you can see the grubbings for those that might or want to do this for themselves... maybe haha.
    So basically my troubles were, a sticking caliper. and the handbrake has some loose travel when applying it.
    Went to biggred.co.uk and ordered a repair kit.
    The offending caliper (and Hole in the Backbox!) for the beady eyed viewers
    So i didnt loose too much brake fluid, i put a plastic bag folded a few times under the cap of the reservoir.. i lost about a cap full in drips
    Splits in the Dust Boot
    No airlines necessary to take the piston out on the rears... just pump the handbrake mechanism, but wear goggles.. brake fluid WILL Squirt out in any direction once the boot comes out of its seat
    Take the spring off, the nut on the rear of the handbrake mechanism and pull off that plate under it, undo the star bolt and take off the other one.. it makes it easier to do before you open up the system and find yourself covered in brake fluid from waist to toe
    These were caked in dust/crap even inside the Dust boot seat.. i dont know the correct tool to do this, but i used a very narrow flat had screwdriver and cleaned it out.. all was smooth after and made the seal much better. I didnt take a picture of the circlip inside here, i forgot. Its under the fluid and is a real pain in the ass to shift out. Just be careful not to damage the smooth surface inside it can be done and this is not under load from the spring.. see the next pic
    I did not see any point in opening this up so left it in tact, but where the o-ring is gave that a good shine it was the cause of my sticking handbrake, the corrosion (very slight) was just enough to make it stiff in the hole and not return to the lowest point. I used some abrasive strips that is used to clean copper pipe (also useful for the tail pipe too!)
    You can see the scoring made, the oring makes the seal inside the housing so as long as you dont take too much off when smoothing this out you will be fine.
    Put it all back together, bled the system and the handbrake is working so smoothly now, it feels completely different. Dont get me wrong if you want just go and buy a new one... but since i have never taken one apart nor attempted to take and thing off the braking lines, it was more to learn something new and not just take off, put on.
    This was my method, some may frown on it, some may not and just laugh haa haa, but it worked for me and have a fully functional caliper and handbrake again! Also its not in great detail, but im tired lol
    If i told you i have to kill you, but i could give you a clue and just rough you up a bit!
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    Good right up !!
    Where did you source the seals, boots, pistons from etc ?? Im thinking of doing mine at some point.
    Jan 2011
    Aberdeenshire
    646
    Very good write up!
    One thing I will say, I had to take one of mine apart, and found the mechanism in your 7th and 8th pics was damaged.
    This is part of the self-adjuster, so I bent the tabs back, removed the internals (some ball bearings and a spring), cleaned it up and refitted it. It worked fine - but would have been so much easier if I had these pics!
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    254
    Excellent write up. Only thing I'd add, as I did the same job a couple of months ago is to add a smear of Lockheed red grease under the dust sleeve to add a little lubrication. In addition, I found putting some marine grease on the hanbrake spring before reassembly and a zip tie around the rubber grommet on the handbrake cable end keeps corrosion at bay, as the cable is prone to fraying.
    Oh and get some chemical metal on the hole on your exhaust back box!
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    Aug 2009
    Stoke on Trent
    114
    Quote Originally Posted by Bradderz_1988 View Post
    Good right up !!
    Hi Bradders, cheers fella. I got them from here Bigg Red
    Great Prices and only 2 days delivery (thats what it took for mine anyway)
    Heres what u get in 1 set for the £26
    Aug 2009
    Stoke on Trent
    114
    Quote Originally Posted by PAULF View Post
    Very good write up!
    TBH The only reason i never took this piece apart was just time, it took me that much time to get the circlip out, daylight and needing the car the next day... plus i could see the corrosion on the bolted side was my main issue. Wish i did take it apart now so i could have seen the internals of it. But i do have the other side to do hehe
    Quote Originally Posted by spartacus 68 View Post
    Ohh, good point! i didnt put and grease under the sleeve, but i did on everything else on the outside.
    The cables are lines with a thin plastic coating... but good point! I will strap mine down later
    Aug 2009
    Stoke on Trent
    114
    Just googled that chemical metal looks really good stuff, been trying to find something to put on it! so thanks fella.
    Ive got some Epoxy Putty in would that do the same job?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,372
    i got as far as that circlip, then gave up.
    Would be interesting to see how you actually got the clip out!
    TD5 Land Rover Defender build
    Aug 2009
    Stoke on Trent
    114
    aragon, i will be doing the other side soon, so i will remember to take some pics of that part of the job lol.. its the more tedious and the reason most dont attempt im guessing...
    Will update as soon as i have got there again lol
  1. what is the best way to remove.LONG CALIPER BOLTS ON THE REAR OF AN AVANT??
    By cominatcha in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th March 2012, 01:34
  2. Which other models have the same rear calipers?
    By diggerbucket in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th November 2010, 13:22
  3. what tool do i need to rewind the piston in my rear calipers ?
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd June 2009, 19:38
  4. which cars share the same REAR calipers as the S3?
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st May 2009, 07:34
  5. Mount the rear Porsche S calipers on Audi A3
    By Spawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2009, 15:14
