Monster MotorsportVolks Autos
Results 1 to 22 of 22
    boost-addict's Avatar
    Aug 2011
    977
    my custom 2.5" exhuast. cost only £168
    ok so im not that handy with a welder, but enough to make good welds. altho it seems i have left one little hole, nothiung major so ill get back under there at the weekend, all in all it took 4 hours, including cutting setting up, tacking then fulling welding and various breaks so the pipe it self
    i bought 3 meters to be sure and bought 6 45 degree bends and a rear exhaust can, i also got s/s wire, cutting blades and tips. so all come to £168
    so basicly for now ive gone from the downpipe at the original location, but will buy 2 more 45 drgree bends and some 60 degree to make up my downpipe, although im not sure if to go 3" as i have a 3" decat to put on
    ive got no before pictures but heres some on the car during, then finnished and one on the floor just before i was to seam weld the joints. out of 2 meters i literly had about 6" of pipe left. would have been a close shave if i didnt buy 3!
    basicly if your good with a welder im just posting this to show you can aviod paying over £350 for what you can do for half the price and a few hours of your time!
    ok so its not a pro job, the welds arnt the best ie seam welded goodness. and the hangers are spare threaded bar i had. but it does the job nicely. no ones going to be looking under my car so for me its all good. of course if your pukka with a welder then obviously you could have it done better, or better still, cut and tack, then take to a shop to have welded up. i did consider but was doing it for expreince and enjoyment more then looks,
    ill get a vid up as soon as i got someone else to hold a camera!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,933
    good effort, but isnt it a bit loud?!
    Also, working under there on a hydraulic jack and a widowmaker
    TD5 Land Rover Defender build
    Aug 2011
    977
    that jack is a 3 tonne jack. aint going no were.
    the scissor jack was there because the front wheel lifted.
    infact its not loud at all. its a bit late now other wise id get a vid, if any thing i was hoping for a bit deeper sound. and a bit more burble at idle. but were see as it beds in. one thing i am getting is a smell when the system gets hot. i pursume this is just a coating on the metal? or might actually be the exhaust paste i used, smells a bit like that. used fire gum paste. reckons its good for over 1000 degress but if that smell is it burning then its useless.
    although it wont matter, ill be doing the downpipe next month and using a v-band clamp. at the downpipe connection.
    so am i best going with 2.5 or 3" downpipe?
    so far got about an hours drive on the system, as hoped, and avoided when making, ive got no bangs or rattles. the system is quite sturdy, enough play for vibration and engine movement but doesn't sway about like a standard system
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,879
    What size is the stock TQS system 2,25" ??
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Aug 2011
    977
    something like that, but downpipe is restrictive, the bend after the cat is like 60 degree!
    May 2010
    194
    Sorry but I'm too distracted by the dangers to look at the exhaust!
    Seriously... a 10 tonne hydraulic jack can fail. Axle stands cost about £20 , your health/life is shirley worth that?
    Aug 2011
    977
    proberly, but thats my concern, thanks for the post?
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,933
    I had a trolley jack fail. Had spent half a morning under the car. Popped indoors for a cuppa and when I came out the car was on the floor.
    Nice effort on the DIY exhaust though, looks better than some of the tat the so called professional custom places knock up
    Life begins at 140mph
    www.passionford.com
    Aug 2011
    977
    i understand the risks, cheers
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    That looks pretty decent to me, i was thinking similar to Kev and it being loud but you say its good then ideal, good effort mate for having a bash yourself, bet your chuffed? What tip is that you have used, is it an RS one or just an oval off another backbox?
    I agree aswell on the jack comments, when i was young and invincible i done the same all the time, now i nick my da's stands when i need them, better to be safe and all that....
    Project RS28 build
    Aug 2011
    977
    yer i know, but whats done is done, i just didnt have stands on me,
    any way. decat on
    sounds real nice, and inspite of thinking the decat would make it sound loud under normal driving it has litlery only changed the tone/loudness the slightest bit at tick over,
    driving theres little change, there is a bit of drone but nothing major.
    also the car does pick up quicker. and its not doing my clutch any favors in 3rd gear!
    i might consider putting in another box. if its a problem, same as the rear one and place that some were in the middle
    TrisLC's Avatar
    Feb 2013
    Cheshire
    333
    A very good effort, fair play!!
    Wish I had the skills and confidence to do this.
    B5 1.8T Quattro
    Aug 2011
    977
    Well i disnt know how well it would come out but its no to bad. I might have to remove at some point and grind down the welds and redo them
    really need to get a vid!
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,360
    looks ok for what it is and costed.
    Just be careful, I lost a brother in law to a hydraulic jack failure last yr.
    Aug 2011
    977
    Sorryto hear that.
    Any way ive been told enough
    can hear the turbo spooling on low revs which is quite cool
    is there a better way other then using a grinding wheel? Thought about a flap wheel?
    My brother jokingly said use some heat wrap. Thought im not a complete bodger
    Apr 2004
    12,360
    id use an angle grinder and a flap wheel and just grind the welded bit. I did it with a mild system many moons ago and it saw me 2 yrs before bits gave up
    It's prob worth dropping it and grinding it if you worried, if not, who looks under there tbh....
    I know you been told, All good in the hood
    Aug 2011
    977
    i didnt mean that sarcasticly. just been said many times, and i do understand its dangerous
    ok cool. any one know the best grit?
    i was using a grining wheel but it just seemed like i was getting no were. so i gave up and thought the same. no ones going to see it but mee, i cant be arsed to drop it till i get my bits for my downpipe
    still pondering 3" or 2.5" !!
    Apr 2004
    12,360
    3 inch all the way
    Aug 2011
    977
    well not all the way but 3" decat, and 3" downpipe to 2.5,
    found a 3" to 2.5" conical reducer will this be ok
    Exhaust Cone Reducer Adapter 2.5" to 3" Stainless | eBay
    Apr 2004
    12,360
    should do the job. Mine is 3 ich turbo back with a 1 cell sports cat....LOL
    Aug 2011
    977
    i was going to go 3", wish i did to be fair. to late now lol,
    ill likley have downpipe back made up next year or when ever, i mean only cost £168 and im sure ill get most of that back selling s/h they dont come up much do they!
    May 2010
    194
    Having bigger going into smaller makes no sense at all and will hurt more than help.
    If anything an exhaust should get bigger along it's length.. but never smaller.
  1. Exhuast Leak only from Cold 1.8T
    By hardhitter in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th October 2012, 21:00
  2. custom made downpipe costs?
    By Bellic in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2008, 20:54
  3. TYRE WEAR - ONE TYRE ONLY -SEVERE!!
    By fraz in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th April 2003, 09:18
  4. MOVED: TYRE WEAR - ONE TYRE ONLY -SEVERE!!
    By fraz in forum General Chat
    Last Post: 28th March 2003, 12:18
