Badger5EM Tuning
    Jul 2007
    58
    6 Speed Gearbox to fit 1.8T AEB engine
    Hi,
    I'm looking to build a trackday car similar to a LMP style car and plan to use an AEB engine from either an A4 or Passat.
    As far as I can tell these have 5 speed gearboxes fitted but i'd like to fit a 6 speed. Westfield used the 1.8T in their XTR4 and fitted a 6 speed box, (pictures below) Can anyone help identify the gearbox code I should be looking for to bolt up to the AEB block?
    6 Speed box in XTR4
    5 Speed AEB box
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,317
    any Audi inline 6 speed box will fit, the bellhousings are common, but most of the FWD ones are from diesels and so the ratios will probably be a bit odd for a petrol...
    TD5 Land Rover Defender build
    Jul 2007
    58
    Did the 1.8 20vT not get a 6 speed box at all? How about the later 2.0 FSI Turbo cars?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,113
    The later B6 model 1.8T's have six speed boxes iirc ??
    Jul 2012
    Guildford
    97
    I have been looking as this aswell, found some good info on gear ratios on one of the GT40 websites but cant find it now. It would appear though that all Audi engines share the same bell housing pattern, one person even quoting 'Audi have never changed their bellhousing fittment'. And the porsch Boxter gearbox is reported to fit also.
    From the B7 they changed the gearbox design and flywheel so that the front diff is infront of the flywheel and the driveshafts are moved forward quite considrably. This gearbox will also fit with a flywheel to suit but some older engine blocks need some modifications to allow the diff to sit where it does. This gearbox also has the starter built onto it and not on the engine as the ring gear ends up being about 6 inches away from the gearbox mounting face.
    I'm looking at putting the S4 engine in the back of a rear engined car, its been done to an Elise and a V8 has been put into an MR2 by Woodsport, they used a B6 2.0 petrol gearbox but as for which model I dont know, whatever B6 2.0 has 6 speeds I guess.
    Lotus Elise Esthi
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,072
    I would be interested in this as my 2nd gear syncro is showing signs of age now. Might be worth swapping to a 6 speed box rather than just get my current 5 speeder rebuilt
    Life begins at 140mph
    www.passionford.com
  1. 1996 Audi A4 AFN... wanting to fit a 6 speed gearbox..
    By SyncroGhia in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd August 2010, 22:35
  2. Fitting a 6 Speed gearbox to a 1.9TDi AFN?
    Last Post: 17th June 2010, 16:32
  3. AEB Engine & 6 speed box
    By B5NUT in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th March 2010, 22:21
  4. 6 speed gearbox fitments
    By imported_scrupes in forum General Technical / How To
    Last Post: 2nd April 2005, 19:59
  5. Breaker for 6 speed gearbox wanted
    By ierax in forum Volkswagen and other VAG
    Last Post: 6th January 2005, 13:44
