Volks AutosEM Tuning
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    381
    Strange handling issue/rear end knock
    Over the past couple of weeks my QTS has developed a slight handling issue. When I go around a roundabout or a hardish right hand turn the rear of the car feels vague and a little unsteady. The rear has also developed a knock which sounds similar to the exhaust hitting the chassis although on closer inspection this doesn't seem to be the case.
    I got the car up on ramps yesterday and can't see anything obvious other than a slight exhaust blow and the rear diff which seems to of sprayed a little oil (will post pics in a bit). I checked the springs which seemed fine as I feared one had snapped.
    I know bushes can be an issue but this seems to of happened pretty suddenly which I wouldn't expect from worn bushes??
    Anything I should check?
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    381
    Pics of rear diff. Could this be my issue or another thing to woory about?
    Feb 2012
    89
    Looks like a "normal" leaky rear diff to me. Probably taken quite sometime for that oil to leak out, plus I'd think if your diff was at fault you'd hear a noise all of the time rather than just a knock going round a corner.
    Can only state the obvious and start with checking all bolts to see if they are tightened properly. Then check everything over including wishbone bushes, track rods, arb, wheel bearings, etc etc.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,360
    The bushes do tend to wear progressively, but when they go the arse end is quite bad at following the front. I ended up replacing the lot to cure mine. I believe that Allermange (sp) do a rear bush repair kit, and it's a night and day difference assuming the tie rods and ARB are OK
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    381
    Cheers for the tips guys. will see if I can get the car on the ramps at my mates work and have a decent check.
  1. Rear end knocking
    By rizzini7 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22nd February 2012, 19:37
  2. Found my rear end knocking........
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2011, 00:03
  3. Rear end issues(car related!)
    By Foxmeister in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th June 2010, 00:15
  4. Handling Issues A4 1.8T SE
    By tony99 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st February 2004, 14:42
  5. (Rear?) Suspension Knock on S3
    By gdwood in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th November 2003, 19:05
