Results 1 to 9 of 9
    B5QUAT's Avatar
    Apr 2011
    The North
    306
    weird tapping noise? Help!
    Noticed the other day with my window down while the car was static quite a loud tapping coming from under the bonnet.
    It sounds to be coming from where the injectors are and it is worse when the engine is warm. It's a metallic tap about once every quarter second.
    Any ideas??? Noisy injector? valves?
    Any help appreciated
    1999 B5 k04'd S4. Eibach coilovers, RS6 front brakes, RS4 Rears.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    Could be the cam chain tensioner due to low oil or lack of pressure also could just be the purge canistor solenoid valve on top of the airbox.
    B5QUAT's Avatar
    Apr 2011
    The North
    306
    Quote Originally Posted by Bradderz_1988 View Post
    Cheers mate I'll check that out.
    B5QUAT's Avatar
    Apr 2011
    The North
    306
    You were right. Oil was low. Topped it up and it's quiet as a mouse. Thanks. Thought these things has a low oil light? Mine never came on???
    Danny-boy's Avatar
    Jan 2013
    477
    Odd.
    I had exactly the same on my B7 2.0T yesterday.
    Sounded like the cooling fan blade was hitting something, very worrying.
    350ml of Castrol Edge and all is perfect.
    I'll be monitoring more carefully from now on!!!!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    How low? I've run mine off the dipstick before and its not made any noises.
    TD5 Land Rover Defender build
    Danny-boy's Avatar
    Jan 2013
    477
    So have I.
    I've had it off the stick before and it's not made noise, this time it was just below min and sounded terrible.
    "Stick a V8 in it!"
    15,370
    Incidentally, on my old A4 which had a knackered oil pump, a combination of hot oil, lots of idling and a low oil level would make it start tapping really loudly.
    Driving around town in stop start traffic used to be really bad if the engine was fully warmed up, and i ended up holding the revs up around 1500rpm while stationary which built enough pressure to quieten it down.
    It was mainly due to a worn out oil pump though, i guess the low oil level just meant the pump had to work harder and it couldnt keep up.
    It stayed like that for about 30-40 thousand miles, although towards the end of that time, any length of idling, even with a full sump, would start it tapping unless you held the revs up. I stuck an oil pressure guage on it and used to register only 8psi of oil pressure at idle!
    B5QUAT's Avatar
    Apr 2011
    The North
    306
    I put a litre in and it was halfway up the stick so quite low!
  1. weird knocking noise - Please Help!
    By waqi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th May 2010, 22:34
  2. Loud Tapping noise Help Please
    By campbell in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th March 2010, 17:01
  3. Help!! 98 A4 2.8 Weird TICK noise from engine after 5 mins drive
    By tonygump in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st October 2009, 21:53
  4. tapping noise
    By dgannon69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th November 2005, 11:53
  5. Knocking/tapping noise on Coupe drivetrain
    By strokes in forum General Technical / How To
    Last Post: 12th October 2005, 03:33
