Monster MotorsportVolks Autos
Results 1 to 22 of 22
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Catch Can location
    Wondering where you guys have fitted your catch can's to.
    Get some pics up.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    Why are you thinking of fitting one Scott?
    tony
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Quote Originally Posted by tonya4 View Post
    tony
    Seeing pictures from what the petrol boys empty out of their catch cans, thinking the diesel is a more oily engine and seeing the amount of oil seeping out of the EGR blank, I thought it would be a good idea.
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    Good thinking!
    Not sure where you'd put one though,maybe on the bulkhead?
    tony
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Good thinking!
    tony
    not sure.
    It needs to be accessible so you can drain it but at the same time I don't want pipes all over the engine bay making it look messy.
    I did think about under the plastic battery tray but not sure i'd drain it or the running of the pipes.
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    Just had a quick look at my bay,it would maybe fit near the power steering res,theres a space there on mine.
    S for draining,how about some sort of quick release bracket so you can lift the can upwards then put a bottle or something under it?
    tony
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    thing is, they are cheap enough on ebay.
    I don't want to start redesign it and costing me more than buying a cheap unit.
    I'll take a look tomorrow at mine. I might be able to hide it under a cover.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    Remove the coolant tank theres probably enough room under there and its only 3x pozi screws to remove it !!
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Quote Originally Posted by Bradderz_1988 View Post
    I forgot about that massive waste of space.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,378
    Why not just setup an oil seperator and pipe it back to the sump? That way, the blowby gasses are "filtered" and the oil drops out of suspension and runs back to the engine, and theres nothing to empty.
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    How would you put it back to the sump?
    "Stick a V8 in it!"
    15,378
    Back thru the crankcase breather hole?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    I don't think I got the room for a pipe in, pipe out and then some where for it to filter.
    It all seems a lot more work than a catch can or even a vent to atmo.
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    wouldn't a vent to atmo lead to oil dripping onto the road though?
    tony
    Aug 2010
    3,136
    tony
    Not necessarily as the catch can should in theory 'catch' the oil and just release the vapours it would only throw it onto the roads if it was getting quite full or over flowing.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    tony
    Yeah but its never an oil slick that pores out the back.
    I would not vent to atmo any way.
    I'd rather a can or back in the engine.
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    If I remember rightly.some older fords(poss mk1 fiesta) had a seperater on the crankcase breather,which would split the oil from the gases
    tony
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    tony
    BMWs still use a oil seperater today.
    Might be an idea to see what oil separators I can use.
    Aug 2010
    3,136
    Any joy on this scott ??
    also anyone done this to there 1.8T who can post some pics of location and piping that would be great !!
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Yes. forgot to post.
    My can will fit below the coolant bottle.
    Loads of room and easy to drain as well.
    So I'm going to put it there, need to get some pipe ordered up and get it routed.
    I got some 19mm stainless steel pipe work here to go with it.
    need to convert the 15mm inlet and out let on the can to 19mm and get the pipes ordered up.
    Aug 2010
    3,136
    Is there any sort of useable bracket under there or you making one ??
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    There is a bracket on the wing that you can bolt the catch can bracket to.
  1. Forge Catch Can Kit Fitted Today :D
    By david_phillips95 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th October 2012, 11:51
  2. Forge Oil catch can -S3 - Group buy ?
    By Whiteatom in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th March 2010, 12:32
  3. BSH CATCH CAN FITTED TODAY.
    By G"MAN in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th December 2009, 18:46
  4. S3 Catch can effluent - What has my catch can caught this month?
    By warren_S5 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th November 2009, 11:30
  5. BSH Catch can group buy offer - CLOSED
    Last Post: 12th October 2009, 09:35
