Badger5Chris Nott
Results 1 to 7 of 7
    Feb 2013
    North Lincolnshire
    12
    Air bag light - on for no reason after removing dials?
    Good evening,
    Tonight I removed the clocks from the car to fit some new chrome rings around the dials etc, I put it all back together turned the car on and now the bloomin air bag light is lit, I don't understand what I could have dislodged/knocked to have this happen.
    A couple of other things I did, not sure if these could be responsible,
    - removed centre console (one around handbrake, not stereo, did this as I wanted to clean under it
    - removed the panel over the fuses next to the drivers door, did this as needed access to bolts to remove large part under the steering wheel.
    I'm annoyed as now I have to have it switched off, and I don't have the equipment to fault find etc.
    Any ideas on how I could have done this by doing the above would be greatly appreciated
    Many thanks
    Michael.
    May 2009
    south yorkshire
    628
    when you remove the power to the dash ,it brings up the airbag light ,needs vcds to reset the light.
    Feb 2013
    North Lincolnshire
    12
    Thank you very much for the reply, I'm sorry I'm new to all this, what is vcds? and if its some kind of equipment I need to get to do this, would you mind pointing me in the right direction to purchase it,
    many thanks.
    May 2009
    south yorkshire
    628
    vcds is a diagnostic tool/cable it isnt cheap however for a genuine one , there are clones available but do not buy vcds lite its cheap admitedly but you are restricted to using it on older models . it works on all the vag group cars
    you can do alot with vcds recode modules ,add keys etc, diagnose faults reset fault codes and service lights .
    you could however ask in general chat if there is anyone local to you to do a diagnosis and reset the light , usually for a few beer tokens or even free if your lucky .
    if you were closer i would gladly do it for you for nothing .
    google is your freind for what you need
    Jun 2011
    Great Melton Norfolk
    1,349
    Michael have a look on the vcds users map,click on the blue balloons in your area identifying members who have vcds.
    Feb 2013
    North Lincolnshire
    12
    Thank you very much for your help, I will look into this now
    Feb 2013
    North Lincolnshire
    12
    Quote Originally Posted by gen.heinz guderian View Post
    Excellent thank you very much
  1. air bag light
    By a4quat in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th November 2006, 21:08
  2. AIR BAG LIGHT
    By Actiondan in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th October 2006, 20:41
  3. Air bag light
    By imported_alex100a in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th March 2006, 21:30
  4. air bag light and wing mirror?
    By imported_spleenboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st October 2005, 17:38
  5. Air bag light !
    By fallmonk in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th June 2005, 17:48
