Badger5JMB Retrofits
    Apr 2012
    featherstone
    Audi A4 2.5 tdi V6 2001 auto
    Hi ive posted on here before regarding my problem but still no solid answers. If i drive my audi quite hard up the rev range when setting off and then back off the throttle and then try to coast i get juddering from the engine. i can put my foot flat down to power out of the juddering. Normal driving round town and motorways is fine, only when i give it a bit of welly it plays up, cold or hot engine. Its like maybe a pressure build or vacuumn problem due to high revs causing something to react because if i take the gearbox out of drive and let the engine revs drop for 5 seconds or so the problem goes away.EGR is blanked off. did it before then . Doesn't have any smoke issues. Car has 97,000mls and is well serviced...any ideas? Anybody with the right answer will henceforth be known as "The Messiah" cos its doing my ead in! PS..no fault codes showing as i had a guy checking with laptop whilst out on a run...
    Jan 2012
    Malton
    276
    I had same symptoms -- turned out to be chronically worn track rod end
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    253
    Worn engine or transmission mount?
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
  1. Stunning AUDI A4 Avant 130 TDi Sport Tip Auto (2004)
    By Manny20vtSingh in forum For Sale/Wanted - Audi Cars
    Last Post: 4th May 2012, 18:29
  2. 2001 Audi A6 2.5 Tdi SE Auto tiptronic
    By owdgit in forum For Sale/Wanted - Audi Cars
    Last Post: 5th November 2011, 11:38
  3. 2001 A6 2.5 TDI SE 110KW auto UK
    By owdgit in forum Diesel forum
    Last Post: 18th September 2005, 19:45
  4. Tuning my Audi A4 Se 1.9 TDi 130 (2001)
    By imported_Coullio in forum Tuning
    Last Post: 19th June 2005, 10:39
  5. Audi A4 1.9SE TDi 130 2001 (Y)
    By imported_Coullio in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th March 2005, 08:23
