Chris NottAH Fabrications
Results 1 to 16 of 16
    Feb 2013
    Bucks
    14
    Question Hello im new need a few bits of advise.
    right i could do with a few bits of help please guys, i have an a4 quattro sport 1.8t estate.
    need help with the following
    • rear washer dosnt work, it pumps water into passenger foot well. is there a join near there or could it be a split?
    • the boot you have to slam quite hard. the lip of boot lid rubs on the bumper. any ideas? could i adjust the hinges?
    • in the engine bay, i have noticed 2 fans on the rad. 1 constant and 1 electric, the engine dosnt seen to get very hot, is this because of the constant fan?or does the system need bleeding for air?
    • and any quick or easy fixs for the computer display in the clocks.? the top section works ok which shows abs fuel warnings ect. but the bottom section has lots of line through it, does it display mpg?
    • oh and abs light is on. any ideas.
    cheers in advance
    Feb 2013
    Sunderland
    7
    If your ABS light is on it is most likely an ABS sensor that has gone, My MK 4 golf went through quite a few of these, The best way to check is to run VAGCOM on your car, I was able to clear the errors to get it through its MOT but ended up changing the sensor in the end.
    Again, with the passanger footwell problem, i ended up changing my door seal as thats what was causing my leak but audi may be different, i am new to audi but im sure someone on here will be able to help you.
    I hope this helps for now
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    450
    What temperature do you get on the gauge?
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    Feb 2013
    Bucks
    14
    i am pretty sure its not a door seal as it only comes in if i use the rear washer. whats a vagcom? diagnostic machine?
    cheers
    Feb 2013
    Bucks
    14
    Quote Originally Posted by Sulli79 View Post
    about 1/4, and the heating is warmish.
    gavsman's Avatar
    Sep 2011
    379
    Pic looks like you have a B5 Avant, you might get some more advise over in the B5 section ( ScottB5 would be the man to ask!)
    A4/S4 forum(B5 Chassis)
    Feb 2013
    Sunderland
    7
    VAGCOM is a diagnostics machine, if there is anyone in your area with one they may be able to check it for you for some beer tokens. if not check these out, they seem to be in your area, just give them a call for a quote on a diagnostics Pitlane Garage MOT Test Centre Luton | Garages in Luton | Car Repairs Luton
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,328
    Quote Originally Posted by gavsman View Post
    Thread moved to correct section. x
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    450
    Temp should sit about 90 degrees, so change your thermostat for a new one, look on the vagcom section and see if there is any body local to you who may be able to scan the car and locate which abs sensor is at fault, pretty sure the estate does feed it's washer that side, but also check your scuttle drain are clear too
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,328
    VCDS (formerly VAG-COM) forum
    click on the blue balloons in your area, a box opens up with the members details, click the link and send them a pm. x
    gavsman's Avatar
    Sep 2011
    379
    [QUOTE=veedub89;1801346]right i could do with a few bits of help please guys, i have an a4 quattro sport 1.8t estate.
    QUOTE]
    With regard to these 2 probs: your LCD display sound to me that it could be knackered, I'm sure someone on here has been able to replace that part ( should be a DIY thread)
    As for the ABS, if there is no-one local to you for VCDS....you could get a cheap cable from ebay & download VCDS Lite, this will be good enough for you to just read fault codes from the car & tell you which ABS sensor is faulty)
    Feb 2013
    Bucks
    14
    cheers for you help guys, does anyone have any idea about the boot lid?
    oh and the badge on the grill and boot says s2, any reasons?
    1,876
    Someone has been a prat and stuck them on there!
    Feb 2013
    Bucks
    14
    wot evan is an s2?
    1,876
    This is an S2 Avant
    1,876
    And the S2 Coupe, I love this car!
  1. Gtting a new front arb, do i need any other bits?
    By salisbury1985 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2013, 20:00
  2. a few bits i need to order
    By Ash187 in forum Parts Requests
    Last Post: 23rd December 2011, 14:44
  3. new A3 owner few question, need some expert info
    By gazsutton in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th May 2010, 16:46
  4. few bits needed
    By jaylake21 in forum Parts Requests
    Last Post: 23rd April 2010, 13:16
  5. Just Picked up my new A4 -A few ?s
    By Donono26 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th January 2004, 18:08
