JMB RetrofitsChris Nott
Results 1 to 8 of 8
Thread: Slow wipers
    Feb 2013
    Grays, essex
    Slow wipers
    Hi there hope someone can help me, bought my tqs a couple of weeks ago, but the one thing that is bugging me is the wipers seem to be very slow, even on fast setting are painfully lethargic is it a common fault?
    Oct 2012
    434
    It's quite common there is a how to on the site, they basically need stripping and regreasing, i have done both of our cars with the motor in situ but it's easier if you pop it on a bench, just don't lose the circlips on the spindles, oh and the arms are more than likely on very tight, i needed a small puller to remove mine, i have now bought a wiper puller.
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    Mine were like this,I sprayed wd40 on the spindles and after a few tries they are now fine
    tony
    Oct 2012
    434
    The problem with just wd'ing is that it washes out quite quickly.
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    Quote Originally Posted by Ian2012 View Post
    I wd it about every 6 weeks now,it's been fine for over a year now.Maybe the problem is caused when they're not used for a while?
    tony
    Sep 2011
    Sunny Bangor. N.Wales.
    288
    I spray lithium grease every so often on the ball joints and spindles.
    2000, A4 2.5Tdi Quattro.
    Tinted, 3600WATTSLoud
    Feb 2013
    Grays, essex
    Slow wipers
    Gonna try wding at the weekend, they just don't seem to change speed.
    nemo2182's Avatar
    Lord wont u buy me a V10 R8!
    Oct 2005
    uk
    110
    WD is a temp fix or not even a fix at all (didnt work for me) Strip them and do it properly. The fault is caused by the metals on the spindels and arm pivots fusing together. There are many simple how to's knocking around, and I have to say I was amazed at the difference, they asolutely fly now!!! But take your time, get a hold of a dimel, some WD, some good old grease. The problem with WD is it will take moisture out the pivot, but will not lubricate it for the future.
    2000 B5 S4 - MRC Remap - RS2 Sparks - Pipercross Element (dried) + Modified Airbox - Forge Divs - Samco Hose's - KW's dropped 50mm - 18" RONAL R41 in gun metal grey - Black Diamond Combi Disc's + Predator Pads - Brushed Alloy Mirrors - Short Shifter - Full Recaro - Carbon Trim - Bose. More to come, watch this space.......
  1. Slow Wipers Take 2
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th October 2008, 22:13
  2. Dreaded slow wipers!
    By JayB5UK in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th February 2008, 12:22
  3. Slow wipers!
    By WilkoS3 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th March 2007, 10:24
  4. Slow wipers
    By Soupie69uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th October 2006, 20:15
  5. Slow wipers
    By chuffer in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2006, 10:05
