AH FabricationsEM Tuning
Thread: ODB Wiring
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    ODB Wiring
    With 3 RNS units sat on my desk, I'm thinking of building a little test rig.
    I got power sorted out, need to get some speakers and the diag port done.
    The speakers are easy but I'm not sure on the diag port.
    Am I able to wiring in a port directly to the rns unit and use VCDS?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Going by this image.
    Going by this I assume I get a plug, give it ground and live, then run 7 (K-Line or K1) and 15 (L-Line or K2) to the correct pins on the stereo.
    Same as the can-bus if I wanted to use that?
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    495
    K and L plus power and a vcds search should come up with the rns as the only address, worth a go anyway
    problems might occur with canbus as missing node numbers so you would need to simulate the nodes to get the data flowing correctly, not worth the bother IMO
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Quote Originally Posted by Sulli79 View Post
    Old school K-Line it is.
  1. AIRBAG WIRE's S3 SEATS
    By lakhan in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th February 2004, 13:48
  2. window wire
    By cradford1 in forum Classic Audi Forum
    Last Post: 11th February 2004, 20:24
  3. how to wire up the foglights to come on alone
    By indica in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th December 2003, 16:45
  4. NewB, need help: Wire color: delta radio
    By VuDuStetson in forum In-Car Entertainment
    Last Post: 24th November 2003, 16:07
  5. Wiring loom from S3 (BOSE SETUP)
    By danbrier in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2003, 23:53
