EM TuningAH Fabrications
Thread: Poor heating?
    Dec 2012
    20
    Poor heating?
    Hi guys. I have a 98 a4 1.9tdi with the fan engine. Heating packed up when the head gasket failed. The head gasket was changed 2000 miles ago and it's been good as gold since and not used a drop of coolant. However, the heating, even on the hi setting is only getting Luke warm and producing no real heat. Anyone encountered this or know if any possible causes?
    thanks in advance
    dave
    Dec 2012
    20
    AFN engine I meant
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,936
    try bleeding the heater matrix using the hole where the pipes go thru the bulkhead?
    TD5 Land Rover Defender build
    Dec 2012
    20
    Can't say I'd seen one as had checked but ill have another look. Cheers matey
    "Stick a V8 in it!"
    14,936
    One of the pipes going into the matrix has a small hole in it, you undo the clamp and pull the pipe back to expose the hole, and any air trapped in the matrix should make its way out.
    Dec 2012
    20
    Spot on. Thanks for the instruction matey. Ill give it a bash at the weekend
  1. Recaros - are they already heated?
    By AlexStanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2005, 17:46
  2. Heat wave
    By kenny15 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2003, 02:10
  3. S3 Heat
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2003, 20:44
  4. How much does the heat affect BHP??
    By Drystone in forum Other Brands & Models
    Last Post: 25th April 2003, 19:41
  5. heated mirrors not working.
    By moschino in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th January 2003, 17:14
