I have a knocking noise again from the front end mostly when cold if i blip the throttle at low rpm in say 1/2/ and 3 gears, i checked it over a few weeks ago and when pushing the engine up to check movement there was a clicking/knocking noise from what appeared to be the 034 snub and bracket so i greased it (the gap between bush and bracket) with some tunap 121 suspension grease and it seamed to cure it but its come back ??
034 dont mention anything of greasing the snub, im leaning towards to much movement in the engine mounts and stiffer ones may cure this to some extent ??
