Chris NottJMB Retrofits
Results 1 to 20 of 20
Thread: ECU UPGRADE !!
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,134
    ECU UPGRADE !!
    Whats involved in swapping the ECU in my TQS to a AGU ECU, could someone specify the full ins and outs ??
    might look at doing this if it seems a good route to go !!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    more or less a streight swap.
    TD5 Land Rover Defender build
    Aug 2010
    3,134
    When you say more or less whats involved ?? What pin layouts need to be changed or parts need to be added IE oil level sensor etc ???
    "Stick a V8 in it!"
    15,350
    Nothing, just plug it in, code the immo and drive. Then remap it as you see fit.
    Mark had some issues coding the immo on his one iirc and ended up disabling it.
    Also it needs to be a specific AGU ecu, the earlier ones are rubbish. I THINK its an 018CJ you need.
    Aug 2010
    3,134
    Can you recode the immo through vagcom ??
    "Stick a V8 in it!"
    15,350
    yes, but you need the SKC for the cluster and ECU, which will require vagtacho or similar.
    Aug 2010
    3,134
    The AGU is 150bhp so would need to swap it over wnd code it when it would be getting mapped ??
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    me7.5 is where its at, AGU ECU is so 2 yrs ago.
    Aug 2010
    3,134
    TBH i havent got the time or money to do the me7.5 conversion dont get me wrong i would love to have that setup, i was just thinking of labour costs involved to map these cars ie chip out, socket soldering and using chips to get the proper map setup in the car.
    when im ready to get the map (when i pull my finger out lol) il be going to unicorn in stockport.
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,751
    I will be interested in how you get on. I would like to get a custom map and think swapping to an agu will give me more options.
    A4 1.8T Quattro
    "Stick a V8 in it!"
    15,350
    Quote Originally Posted by Soupie69uk View Post
    Didnt you sell your K04? No point wasting money custom mapping a stock turbo IMO.
    Apr 2004
    12,520
    TBH, if you are going to use Rick and get him to solder a socket on etc, you just as well use your ECU and have it all done to that. I wanted flashable becasue i knew my spec would change. so flashable seemed the way forward. Otherwise, there is nothing wrong with a dumb ECU, niki has extracted 344 from Prawns hybrid race car with no problem using an emulator,. Emulate lots, solder once
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,751
    Yeah I am meaning for in the future, hopefully get something bigger than the K04.
    Already paid Star £500 for my map on the standard turbo and decat about 8 years ago so not going to map that again.
    A4 1.8T Quattro
    Aug 2010
    3,134
    Quote Originally Posted by Byzan Pics View Post
    i was thinking an AGU ecu as i may want to go a differant route with the car ie stroker or BT depending on what bits i can get on a budget as of recently the scrappers i use actually no a lad i worked with who worked for them stripping there cars and they have my number if they have any citroen/peugeot related querys and jobs that they might have for me so i may be able to source a spare block and head from there for next to nothing as hes a sound guy and may sort us out and also other bits he has maybe an ABF crank lying around and slowly build it up bit buy bit. Well thats my plan but need to move house first and get settled and finacially stable as money burns a hole in my pocket lol
    Aug 2010
    3,134
    Few q's on this subject,
    1. How easy is it to de immo the agu ecu
    2. Could i run the agu (stock map) with a 3bar fpr, 3" maf, injectors and fmic on stock rods etc ???
    3. i have analogue clock so will this be a relatively easy swap regarding immo2/3 and just be straight plug and play ???
    Apr 2004
    12,520
    Quote Originally Posted by Bradderz_1988 View Post
    24c02 chip needs removing and reflashing
    yup, i'd think so, probably get deviation codes due to your turbo
    Analogue clock is immo 2 and may adapt correctly, mine didnt for some reason i never fathomed, it'd adapt and light would go out, but car wouldn't run for longer than 3 secs
    Aug 2010
    3,134
    Deviation codes i dont follow ?? If i buy vagtacho will it be easier to code the immo ??
    Apr 2004
    12,520
    Vag tacho will help yes, The ecu may flag up codes for boost deviation. Because your turbo flows more than it's expecting to see for a given load. That of a MAF signal too high
    Aug 2010
    3,134
    Could that be sorted when it gets a custom map and some shiney new rods ??
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,641
    If its of any use, I have a couple of ME7.1 ECU's knocking around as im going WB. They are from an APU, and one has Immo defeated already.
    Currently rolling in a SKODA!!!
  1. Audi ecu upgrade.
    By oldlaw in forum General Technical / How To
    Last Post: 23rd March 2007, 21:03
  2. APR ECU Upgrade
    By cclarke184 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st June 2005, 17:38
  3. Revo ECU upgrade for TDI
    By shresh in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th February 2005, 19:17
  4. ECU UPGRADE
    By Reesmith in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th November 2004, 11:10
  5. complete ECU upgrade
    By imported_GarretLogan in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th July 2004, 13:13
