AH FabricationsJMB Retrofits
Results 1 to 12 of 12
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,031
    AFN ECU and chipping
    Toying with the idea of getting my ECU chipped but since its old and can't be done via the ODB port, I've been thinking about getting one off ebay.
    Send that away to get chipped, swap it over with mine and then sell mine on.
    I guess it works in theory but is there any difference between newer or older AFN ECUs?
    Would it be advisable to get a newer 110 AFN ECU over a older or same age as what I'm running at the moment?
    Thoughts?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Mar 2012
    41
    I have a similar problem with mine. 1.8t AEB. Ecu unable to communicate via ODB port. I have been told I could use an AGU ecu. Not quite sure if this would work, and then have that re-mapped. Could you not do anything similar. Don't know much about the diesels I'm afraid and any input on my predicament would also be appreciated.
    Jul 2007
    London
    3,258
    What year is your b5 ? There are 3 types of ECU fitted on the b5, 1 is a EDC15 and is writeable trough the OBD- only fitted to very late facelifted b5 with AFN/AHU/AHH and AVG engines. the other two are a MSA15 type ECU's and will require old chips removal and new sockets to be soldered to the PCB.
    FOR SALE:
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,390
    Are the ECU's interchangable?
    IE can he find an EDC15 and fit it to his car? Or are the IP's different on the EDC versions?
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,031
    Quote Originally Posted by adamss24 View Post
    1998.
    So no chance of it having a EDC15 but like Aragorn said.
    Can I fit one?
    EDIT:=- Would I need a ECU from a Auto since mine is an Auto?
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,651
    Quote Originally Posted by ScottB5 View Post
    1998.
    Can I fit one?
    Autobox ECU is separate IIRC. should just need coding with VCDS. so could use any.
    Currently rolling in a SKODA!!!
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,031
    Quote Originally Posted by Arrkon View Post
    That's what I'm hoping and going by what Adamss said, if I can fit a EDC15 ECU to my car. I'd be laughing..........Hopefully.
    "Stick a V8 in it!"
    15,390
    Petrol ECU's cant be "coded" for an Autobox. The actual program code the ECU runs is different. Not sure if diesels are the same, i believe some later diesel ECU's are switchable between manual and auto, but not sure if that applies here.
    Jul 2012
    cambridge
    10
    check out audiparts4you on ebay he will sort you
    Jul 2007
    London
    3,258
    I have a chipped ecu done by superchips, it will work on your and it does not need codding. I could part with it for the right money...
    FOR SALE:
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,031
    Re: AFN ECU and chipping
    Hmmm, could be interested.
    Jul 2012
    cambridge
    10
    what gains did it give you what you looking for it
  1. tiptronic and chips
    By ribena in forum Diesel forum
    Last Post: 14th June 2005, 14:36
  2. Springs and chip for a A4 quattro
    By a4restinlow in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd December 2004, 05:34
  3. TDI - DSG and chipping
    By GibsonLP in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th October 2004, 18:21
  4. ECU and check engine light
    By imported_utquattro in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th September 2004, 20:21
  5. Exhaust and Chipping Questions??
    By imported_BiTurboS4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th August 2004, 21:06
