Volks AutosMonster Motorsport
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    Injector question
    My 1.9 tdi AFN has just passed the 200k mark
    I was thinking of fitting a set of new 0.216 injectors in it
    Has anyone done this on here before?
    Any pros or cons?
    Is there anything else I need to do in conjunction
    cheers
    Jul 2007
    London
    3,213
    You will need a bigger turbo to compliment the nozzles ! Gt1749VA off the pd130 works well or you can fit the bv43, both plug and play ! Add a chipped ecu and a PD130 intake with pd 130 boost hoses and a EGR delete pipe and you'll have enough grunt to mess up with more powerful machinery whilst still retaining 50Mpg ! I have a chipped ECU from superchips with maps for 155Bhp and also a pd 130 intake manifold and 0.216 injector nozzles i could part with ! Also have a full worked engine with rods/lower CR, ported head, 11mm pump, was running in excess of 200Bhp with a BV43 turbo. With 0.216 i expect it to run 180Bhp minimum, with race 520 or equivalent it should put in excess of 220-240Bhp !
    FOR SALE:
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    Not looking to go too mad, as she is an old lady as well as being my daily.
    Pm me some figures on the manifold and chip and we can have a look see.
  1. To do or not to do that is the question/ Prod recall Injectors?
    By zollybosher in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th March 2012, 18:04
  2. injector question
    By Pauls3bam in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2012, 22:41
  3. next question...whose got some AJL code or tqs injectors spare
    By jcb in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2010, 21:01
  4. Drilled or Slotted thats the question?
    By Tweaky in forum General Technical / How To
    Last Post: 23rd February 2003, 00:21
  5. Couple of questions for admin...
    By MickHumphrey in forum General Chat
    Last Post: 2nd January 2003, 17:04
