AH FabricationsEM Tuning
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By aragorn
Thread: Oil temp and Coolant temp gauges not working.
    Jan 2013
    59
    Hi everyone, my coolant and oil temperature gauges are not working, I checked with vag-com and it had a fault with the coolant temp sensor. I have since changed the sensor but the gauges are still not working.
    Has anyone had the same faults etc?
    Thanks J
    Feb 2013
    southampton
    43
    i have same fault changed both sensors still not working
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,934
    Thermostat is probably dead.
    The guages are working, the engines just never getting above 60c.
    jas828 likes this.
    TD5 Land Rover Defender build
    Feb 2013
    huntingdon cambridgeshire uk
    42
    mine was like that when i bought it changed thermostat all sorted 90c water 80c oil within 10 miles driving
    Feb 2013
    southampton
    43
    same changed water pump thermo stat both temp senders still never reads above 60 on either
    "Stick a V8 in it!"
    14,934
    Cheap/crap stat?
    Do you have climate control? If so you can view the actual temperature on there which will help you diagnose.
    Hold recirc and press the up arrow, the display will change to 1c.
    Use temp +/- control to make it say 49c
    Press recirc button again, and display will change to show the coolant temperature.
    If you start the car from cold it should be around the outside temp, and you should be able to see it climb as the car warms up, if the thermostat is good it will rise to 90c within about 4-5miles of driving, and should then stay there.
    Feb 2013
    southampton
    43
    yes have climate control and used oem sensors lol will try that trick thanks aragorn
    Jan 2013
    59
    Thanks for the replies, I will change the thermostat and take it from there.
  1. coolant temperature gauge not working.
    By fdt140876 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st March 2012, 00:16
  2. temp gauge not working :(
    By S3_nick in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2011, 16:55
  3. 95 1.8n/a temp gauge not working?
    By andybnwc in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th October 2008, 22:36
  4. Temp gauge not working...
    By NILESH in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th May 2007, 01:33
  5. temp gauge not working
    By nickstevens in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd November 2005, 01:52
