    Jan 2013
    Grinding sound - OEM Avus wheels and Brembo HC
    I need help. This week I went from 18 inch alloys back to standard 17 inch Ronal Avus alloys with new Michelin tyres. (To get rid of scrubbing).
    The car is fitted with bigger than standard Brembo HC discs on the front.
    Everything seemed fine during the swapping process, I removed the 10 mm spacers that were used for the 18's, and put the long bolts to one side and stuck the 17's on with new shorter bolts.
    Set off for a drive, and within metres I heard a noise which sounded like I'd forgotten to tighten the bolts on one of the wheels (I hadn't obviously) but then within a second it went away.
    The worrying thing is there's a grinding noise from the front wheels, it's there all the time when on the move and is not suppressed by braking and it feels like the car isn't able to completely free wheel. I've looked at the wheels and there doesn't seem to be anything obvious rubbing, although the calipers are close to the back of the spokes.
    Can anyone help? Can I not run these wheels and discs together? I've only driven a handful of miles because of this issue.
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,746
    Are you sure the bolts are not slightly too long? I have been caught out by that before.
    I would jack it up and spin the wheel by hand to see if it becomes clearer?
    A4 1.8T Quattro
    Jan 2013
    I have thought about the bolts but if anything I was worried they were a bit short, even though they tightened up nicely. I tried the longer bolts from the previous wheels and they just spun and spun and never tightened. The new bolts are supposed to be the correct length for the b5 s4. I might try putting the spacers back on with the longer bolts and see if that changes anything....
    Cheers though.
  1. Lightest OEM Audi 18" and 19" wheels?
    By munchkincoupe in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th January 2013, 19:35
  2. S3 Replica Facelift Wheels and OEM Centre Caps
    By terrymcg in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th August 2010, 16:09
  3. Are spacers required to clear Brembos under 17" Avus wheels
    By JD09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th May 2010, 19:02
  4. 17" Avus OEM wheels and tyres for sale
    By pure in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 21:18
