Volks AutosEM Tuning
Results 1 to 7 of 7
Thread: Sticky cv boots
    Oct 2012
    429
    Sticky cv boots
    I have just used one of these today on one of my rear outer driveshafts, be interesting to see how long it lasts, the glue didn't like going off in this weather so i helped matters along with a mild setting on my hot air gun, the clips that came with it were interesting, more like a metal cable tie without the little serrations to lcik into just a smooth band. hmmm
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    the smooth band metal ties need a speical tool to do them up afaik.
    A mate of mine used a glue-up boot and found it fell apart inside a few months. When the proper boot is about £15, its bit of a waste of time doing anything else tbh.
    TD5 Land Rover Defender build
    Oct 2012
    429
    TBH i had had enough of messing around in the freezing cold today so went for quick fix, couldn't face removing suspension bolts
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    They're ok as a temp fix but nothing more.
    Life begins at 140mph
    www.passionford.com
    Mar 2012
    41
    I tried some prior to Christmas. Both needed replacing last month as they'd split. Re-did them again and now back in the same position. This time round I've bought gearbox oil and intend on swapping that and removing both shafts to replace correctly. I'd never buy these again. Like the man said a little earlier in the thread. Good for a temporary fix, not as a permanent fixture.
    Oct 2012
    429
    Oddly enough i spotted a few spots of grease on the inside of the wheel today, need to investigate further
    Mar 2012
    41
    That'll be a split. I'm pretty confident too. I spent a few hours making sure mine were fitted properly. Every time they have gone where they are glued.
  1. Audi's have sticky throttles?
    By sideshowbob123 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 16th December 2003, 10:10
  2. Cb joint boot
    By Jettco in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th November 2003, 22:40
  3. Andi A4 boot spoiler
    By andyer in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th November 2003, 17:32
  4. Boot Spoiler
    By stelios24 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd October 2003, 16:12
  5. Leaky boot
    By skoller in forum Classic Audi Forum
    Last Post: 20th January 2003, 23:32
