AH FabricationsVolks Autos
    Oct 2012
    425
    A4 quattro rear diff oil seals
    Is it possible to undo the driveshaft from the diff without removing a whole load of stuff?? I was thnking maybe unbolting the diff carrier plate to give it some wiggle room. Just looking for an easy way to pop the shft off the diff wihtout having to undo half the car.
    ta
    Ian
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,318
    Just remove the top bolt from the rear upright and tip the upright out/forwards. This gives you enough slack on the shaft to pop it free and move it out of the way.
    TD5 Land Rover Defender build
    Oct 2012
    425
    Thank you
    Ian
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,113
    I did it slightly different by dropping the lower arm i didnt remove the shaft from the hub as you can see and as the bolt was fookin well tight.
    Oct 2012
    425
    I was hoping to be able to do it using ramps, as i am not that keen on crawling under the car even with axle stands, plus i know that bolts is well rusted onto the car,
    thanks
    Ian
  1. Leaking Diff oil seals a4 quattro
    By Cam in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th May 2011, 19:51
  2. Replacing quattro rear diff seals.
    By ian52 in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th June 2010, 20:27
  3. Rear Diff Oil and Seals
    By aragorn in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th September 2009, 22:35
  4. A4 Quattro Rear Diff Seals
    By kipps in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th November 2005, 18:50
  5. A3 Quattro Rear Diff/Haldex Coupling Oil Change
    By imported_rob911 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2004, 10:50
