Badger5Monster Motorsport
Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By Bradderz_1988
Thread: Bov or forged diverter????
    Rbarlow93's Avatar
    Feb 2013
    Beaver dam , wi
    9
    I will be getting my first audi on monday and I love the sound some turbo cars make and I want my audi to make that sounds I saw the hks ssqv kit that on the 1.8t but also the 007p forged diverter what is my best route
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,114
    Upgraded diverter valve anything else and you will have running issues !!!
    Rbarlow93's Avatar
    Feb 2013
    Beaver dam , wi
    9
    Ok
    Well if I upgrade my diverter valve will it make that noise when it spools and which diverter should I get
    Aug 2010
    3,114
    I run the forge 007p but you could go for the 008 !!
    only way you will get spool noise is if you mod the airbox below the filter or fit a cone filter which deletes the airbox some people disagree with running them but i run one it down to you which way you go the honda s2000 mod looks good as its a paper filter in a cone shape sodoesn't need to be oiled but will need some sort of piping that has a bigger id one end as the filter has a 3" kneck iirc
    Rbarlow93's Avatar
    Feb 2013
    Beaver dam , wi
    9
    Ok
    So what would happen if I ran the hks ssqv kit made for the audi
    Aug 2010
    3,114
    When you change gear or back of the throttle and the ssqv 'dumps' the MAF sensor has already accounted for that air and the ecu has matched that figure with the amount of fuel to be injected, so you end up getting a few seconds of the car running rich its bery noticable when at idle if you blip the throttle the revs will start to hunt !!
    Stick to a piston type diverter and you will be problem free as long as you service it every year. If you the dumping/spool noise you will have to remove the airbox or mod it !! You could fit the forge splitR which will give you more audible dumping noise but no spool noise !!
    and you haven't said what car your getting audi 1.8T ??????? LOL
    Rbarlow93's Avatar
    Feb 2013
    Beaver dam , wi
    9
    Ok
    Yes sorry the 1.8t it already has k&n intake borla exhaust awe tuning and short shifter unknown on brand only 92,000 miles its a 01 quattro im excited
    Oct 2009
    190
    My 1.8t is running a cone filter with quite an aggressive map by that I mean it's not gradual just loads of lag then boooost. The chatter from my k&n is quite loud. Probably not a good thing but so many problems with my car I've given up caring
    Aug 2010
    3,114
    Chatter ?? What DV you running ??
    Rbarlow93's Avatar
    Feb 2013
    Beaver dam , wi
    9
    Ok
    Well im gonna look into the diverter valve what are some good ones
    Oct 2009
    190
    Sorry wrong word *flutter
    Aug 2010
    3,114
    Sure your DV's not shot ???
    Arrkon likes this.
    Rbarlow93's Avatar
    Feb 2013
    Beaver dam , wi
    9
    Hey
    Is a 007p any good
    Oct 2009
    190
    Could well be but penny valve is knackerd so it's being driven until it dies
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,641
    im running a 007p with a green spring, seems (IMO) to hold boost better, be a bit smoother and quicker than the 710n...
    Currently rolling in a SKODA!!!
    Rbarlow93's Avatar
    Feb 2013
    Beaver dam , wi
    9
    Ok
    And does it make the turbo and louder with the 007p
    Arrkon's Avatar
    Oct 2010
    1,641
    No, as Bradderz has said further up, you would need to do the drilled airbox mod, or fit a cone/mushroom filter (with adequate heat shielding).
  1. forge diverter valve 007
    By degsy1967 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th August 2010, 17:15
  2. Is this the correct Forge diverter valve?
    By Johnnyb in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th December 2009, 17:24
  3. Forge diverter valve 2.0T
    Last Post: 22nd October 2007, 16:50
  4. New Forge diverter AND blow off valve?!?
    By Cossie_boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2007, 14:31
  5. Forge Diverter valve
    By starski4578 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th September 2005, 18:42
