AH FabricationsEM Tuning
Thread: Clicking noise
    Jan 2013
    Darlington
    44
    Clicking noise
    Everytime i pull away theres a cluncky clicky noise coming from drivers side.
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    254
    Quote Originally Posted by Andyroo83 View Post
    Can you be more specific please?
    Does it sound suspension related? Is it a metal on metal sound? Could be a couple of things. The most obvious will be the outer CV joint. Check the rubber gaiter hasn't failed allowing the grease out and dirt in. Another option is a worn tie-rod end, but this is more a 'clunk' on take off rather than 'clicky' noise. Final thing, again suspension related is the coil spring. Check its still intact. Not unusual to lose an inch or so on either end due to stress and corrosion which allows it to flex in the strut assembly. You really need to raise the car, pop the wheel off and take a closer look.
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    Jan 2013
    Darlington
    44
    Its as i pull away theres tht noise coming from front drivers side suspension area. Just had the cv joint and boot changed. Will have to lift it to have a good look. Heard the arms go on them. Cheers mate
    Jan 2013
    Darlington
    44
    Just noticed the noise last night aswell so and good look over this weekend and i will et back to you
    Dec 2008
    Aberdeenshire
    254
    You're not wrong there! Could be upper arms, in which case you'll need to release the dreaded pinch bolt.
    Useful link here to identify upper arm wear.
    Bad Upper Control Arm - YouTube
  1. s3 strainge clicking noise help !!!!!!!!
    By stus32007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th February 2008, 11:26
  2. Clicking noise in 1st gear
    By bmerrilees in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th November 2004, 17:13
  3. clicking noise as front wheel turns on A4...
    By imported_bpascua in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th August 2004, 21:59
  4. clicking noise from air vent???
    By xdam in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2004, 00:53
  5. clicking noise on tickover
    By pwnorman in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2003, 18:22
