Results 1 to 11 of 11
Thread: daga daga
    johnyj's Avatar
    Jun 2004
    253
    daga daga
    my tsport thinks its a tdi on starting the car theres a load knocking noise.
    this goes after a few secs as the oil gets pumped round.
    sometimes it doesnt go away.
    it sounds abit tappety sort of thing.
    any ideas
    cheers bigears... [img]/ubbthreads/images/graemlins/grin.gif[/img]
    Sep 2004
    Glasgow
    919
    Re: daga daga
    isnt that normal on the 1.8T? [img]/ubbthreads/images/graemlins/smile.gif[/img]
    hop2407's Avatar
    Oct 2004
    Derbyshire
    1,408
    Re: daga daga
    [ QUOTE ]
    [/ QUOTE ]
    Not sure.... It aint on mine anyway. Pretty quiet from the moment the key is turned.
    What Oil you using man ?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,312
    Re: daga daga
    Mine's a 2.8V6. There's a slight rattle as I start it, & it goes away in a second or so. It's just the bearings turning before fully coated in oil. Nowt to worry about, provided it's not still doing it after ten seconds!
    Jul 2005
    2,488
    Re: daga daga
    my s3 sounds like a bag of nails when started, then afer 1 sec sounds 'normal'.
    to be expected on any car with hydraulic tappets.
    johnyj's Avatar
    Jun 2004
    253
    Re: daga daga
    cheers guys mines the same normally it goes after a few seconds but sometimes it stays and even after reving it stays.
    turn it off after a run and its gone.
    do u think its something sticking?
    using synthetic oil had a change 6 mnths ago with filter.
    Oct 2004
    Southampton, England
    86
    Re: daga daga
    Audi18t - you deffinately have something wrong.
    i dont know which of you have the 1.8t with VVT or without but ive found the VVT chain to be the noise on start up, this is because the the chain tensioner uses the oil pressure and being in the head wont have pressure from the second you turn the key, hense rattley chain for second or two [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Jul 2005
    2,488
    Re: daga daga
    whats the milage? how well has it been previously serviced?
    could easily be a blocked oil guide thats staving the oil to the head.
    just as possible on a high miler though, it could be worn tappets or cam lobes.
    you say its sounds tappetey? it it a ticking/tapping toise or a knocking noise as you described?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    Re: daga daga
    get the oil pressure/pump checked out mate, the noisiest i have ever heard was a 2 sec rattle on cold start up. never during the whole journey till shut down.
    johnyj's Avatar
    Jun 2004
    253
    Re: daga daga
    cheers guys its got 80,000 on it had the cambelt waterpump and tensioner done about 5mths ago.
    ill get a oil and filter change and ask my man to check the oil guide and pressure pump.
    its abit weird as sometimes on start up its a 2sec noise and then goes.
    ant other things i can check while im there?
    johnyj's Avatar
    Jun 2004
    253
    Re: daga daga
    got the engine and gearbox oil changed and they used an aditive for the sticking valve for an extra 10.
    has solved the problem andwhich saves having the valves compressed which i would imagine alot of money.
    next week hes putting it on a valve and injector cleaning machine for 50 as i told him its pinking abit.
    he rekons this should change the drive of the car.
    he disconects the fuel tank and runs the car on hes machine for a couple of hours.
    anyone had this done?
