Badger5Sky Insurance
Results 1 to 7 of 7
    Cam
    Dec 2010
    Sheffield
    32
    A4 Quattro driveshaft flange removal
    I have a 1999 A4 quattro. The outer CV boots were torn. Ive split the driveshaft and replaced the boot. I also want to renew the flange oil seal insde the gearbox but cant get the stubby part of the driveshaft out. Can anyone explain how to do this.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,288
    its essentially pressed into the bearing inside the box, you'll need to use a pry bar or puller or similar to get it out.
    TD5 Land Rover Defender build
    Cam
    Dec 2010
    Sheffield
    32
    Thanks for your message. Will it slide out if pulled with some force?
    "Stick a V8 in it!"
    15,288
    yes, but you'll need a slide hammer or similar, pulling it with your hand isnt going to do anything.
    As for getting it back in... good luck :P
    Cam
    Dec 2010
    Sheffield
    32
    This is a job i havent done before. Any advice on how to get it back in?
    "Stick a V8 in it!"
    15,288
    ETKA says "Drive in with drift VW295" :P
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,108
    Block off wood and a hammer !!!! Lol
  1. A3 Quattro Rear Disc Removal
    By colinjmatt in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th August 2012, 21:17
  2. Driveshaft/CV Removal
    By jaylake21 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th July 2012, 07:12
  3. FWD Driveshaft Flanges Needed!
    By IN 2 Deep in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th October 2009, 10:56
  4. a3 quattro gearbox removal??
    By Craigybaby37_A3quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th March 2007, 20:52
  5. ABS & driveshaft removal - B5 quattro
    By Griffter in forum Handling
    Last Post: 29th September 2006, 08:23
