Sky InsuranceBadger5
Results 1 to 15 of 15
    Oct 2012
    432
    Rear diff plug disappeared wtf
    So i am under the car today (see other thread) and i have diff seal that's gone maybe both sides, so i am looking for the filler to tpo it off for now, i am no stranger to quattro's btw, so i look on the left side hmm not there i look on the right side hmm not there either, i look again on the right side (drivers) and have scrape around nothing it looks like at some point and this is a guess some one has sheared a tool in the plug and it's now rusted flush with the casing.
    Suggestions as to how to fill the diff please
    Ta
    Ian
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    I used an air chisel with a very fine point tip to just shock the old one loose i re-used mine as it wasnt rounded but if yours is fubar then id order one from stealers !!
    Oct 2012
    432
    but there is nothing to get a hold on like it no evidence of a plug being there really odd i must say, unless of course i am blind!!
    Aug 2010
    3,138
    It does seam to sit quite flush iirc maybe its caked in crap and oil try blasting it of with a jet wash its there somewhere lol
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,381
    its to the rear of the drive flange on the drivers side of the diff.
    Pic here:
    TD5 Land Rover Defender build
    Oct 2012
    432
    Thanks for the location pics, looks like mine is rusted and full of broken tool that is now flush with the casing, i suppose the only way to get oil in it is when doing the oil seal??
    "Stick a V8 in it!"
    15,381
    i tried to fill mine thru the driveshaft hole, and just ended up covered in oil.
    air chisel like bradderz suggests, or perhaps welding a bolt on might get you somewhere?
    Oct 2012
    432
    if i had welding kit that would be the way forward, i will have another look and see if a chisel will work,
    Dec 2011
    149
    right , I know this sounds daft , but that casing is alu , so get yourself a magnet , and when it sticks to the case somewere like in that picture , you have found your metal plug
    Oct 2012
    432
    it would also be the rust spot then, lol
    Jan 2011
    Aberdeenshire
    646
    Depending on your acces to tooling (such as a right angle drill)
    Drill into the broken tool, screw in a hefty self tapper and lever it out to remove the tool?
    Drill into the broken tool and use a DECENT 'easy-out' to remove plug and tool together?
    Another method is to buy another plug, then drill two 1/8" - 3/16" holes into the plug and knock in two pins (such as phillips screwdriver shafts) you can then put a bar between them and unscrew the plug and tool.
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    Oct 2012
    432
    Diff plug was full of rust and cack, cleaned it all out to find it's so rusted as there is nothing for any kind of tool to get a grip on, tried chisel and hammer, no joy with that. so i am looking a nut weld job or maybe drill the centre out a bit tap it and pop a bolt in with a sealing washer.
    "Stick a V8 in it!"
    15,381
    just get a bolt welded onto it, M10 or M12 bolt will fit into the rounded out hole, blast of weld to secure it and the heat should break it free as well.
    boost-addict's Avatar
    Aug 2011
    977
    what oil are you using, and do you sugest using molyslip, its like a sealent for slow leaking diff seals, wondered if this runins any thing?
    whats the best oil i can use?
    Oct 2012
    432
    The correct grade is 75w90, some folks use semi synth some use fully, personally i wouldn't run molyslip but i would use millers oils stop leak, so when i get the damn plug out i will be popping some of that in after doing both drive shaft seals.
  1. Rumbling Noise - rear diff?
    By NicA4V6 in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st March 2006, 13:35
  2. A4 Quattro Rear Diff Seals
    By kipps in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th November 2005, 18:50
  3. Rear Diff Leak
    By imported_rashpal1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th October 2005, 20:58
  4. What oil/fluid goes in S3 rear diff?
    By Petegti in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2005, 12:01
  5. A3 Quattro Rear Diff/Haldex Coupling Oil Change
    By imported_rob911 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2004, 10:50
