    Oct 2012
    385
    Replacing quattro rear diff carrier bushes how i did it
    Finally got round to doing the diff carrier bushes today, ran the back of the car up on ramps, removed the carrier plate drilled out the rubber in the middle in a few places then twisted the metal core out, hammer and chisel to remove old bush. Now here is the interesting part, as hard as i tried with big sockets to squeeze the new bushes in they wouldn't go, seem to be made out of soft metal that deforms easily, so what i did was to get a piece of wood 2" x 4" as it happens drilled a slightly smaller hole and forced the metal centre in so it was nice and snug, back to bench vice got it all square and pressed them in no bother, needed a little tap from the hammer to get them all the way in and hey presto.
    Gear change much improved.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    the rear carrier bushes are plastic cased not metal.
    They also only like to go in one way, one side of the carrier is tapered, the other isnt, if you try to push them in the wrong side they tend to get stuck!
    TD5 Land Rover Defender build
    Oct 2012
    385
    I wasn't sure if they were plastic or soft alloy, they seemed to like biting into the wood rather than sliding off the socket, and yes a chamfer on one side of the carrier plate.
    jcb
    Sep 2005
    uk
    4,070
    just tiger sealed my old ones in place
    very firm now!
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,875
    Had no issues pressing in as running apikol bushes they just pop in either side then metal sleeve insert took me literally 1 minute to fit new bushes !!!
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Oct 2012
    385
    I have now cured the bump think gearchange thing to around 92% satisfaction level, i think a tiger seal of the front mount and i am done.
  1. B5 quattro rear diff bush
    By Ian2012 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th December 2012, 17:33
  2. Replacing quattro rear diff seals.
    By ian52 in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th June 2010, 20:27
  3. A4 2.8 v6 quattro rear diff bush
    By audi1664 in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th November 2008, 20:35
  4. A4 Quattro Rear Diff Seals
    By kipps in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th November 2005, 18:50
  5. A3 Quattro Rear Diff/Haldex Coupling Oil Change
    By imported_rob911 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2004, 10:50
