JMB RetrofitsSky Insurance
    Oct 2012
    434
    Pre facelift trim removal around radio
    How do you remove the wood trim that surrounds the radio and heated rear switches etc, just can't seem to figure it out and don't want to chip it or break it.
    thanks
    Ian
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Think you have to remove both the radio and heater controls as theres screw behind them and the rest of it is on clips iirc !!!
    Jan 2013
    Norwich
    127
    Quote Originally Posted by Ian2012 View Post
    thanks
    Ian
    Hi Ian,
    Just done this myself to replace both the radio and climate control unit, using a thin screwdriver you can tease the clips away at both the top and bottom of the trim then, to avoid breaking it, you must dismount the stereo and pull it far forward as possible, you'll then see 2 8mm bolts that are securing the trim to the center console either side of the stereo unit itself, undo them and simply side over the stereo and there you have it, job done. The climate control unit need not be disturbed.
    '92 VW Corrado 20vt
    '98 Audi A4 Avant TDi 110 - EGR delete...
    '08 BMW 320d Edition M-Sport Touring
    'You screw up just this much, you'll be flying a cargo plane full of rubber dog sh*t out of Hong Kong'
  1. Fit cupholders to pre facelift without any Mods!!!
    By andrewjones in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th September 2013, 16:13
  2. pre facelift S3 Lower door trim
    By cwisy_S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th January 2013, 20:56
  3. Piano black s3 trim in pre-facelift
    By Adam Davis in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th August 2012, 20:56
  4. A3 8p 2008(pre facelift) concert radio
    By Burkin in forum For Sale/Wanted - Audi Parts
    Last Post: 4th August 2012, 16:36
  5. A3 1.8T PRE-FACELIFT XENON CONVERTION
    By wezhaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2004, 22:57
