EM TuningVolks Autos
Results 1 to 23 of 23
Thread: ASR Retrofit?
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    ASR Retrofit?
    ok, so someone at work got me thinking.
    Would it be feasible to retrofit ASR to a facelift B5? I'm not talking full ESP, just basic traction control.
    could it be as simple as swapping the ABS modulator to one that supports ASR, such as an S/RS4 B5 or a B6.
    Looks as though the Bosch 5.3 unit 8E0614111G or 8E0614111AJ can be re-coded to be Non CANbus, So could be a winner...
    http://wiki.ross-tech.com/wiki/index.php/Audi_A4_(8D)_Brake_Electronics_(Bosch_5.3_ABS/EDS/ASR)
    Anyone done this before?
    Currently rolling in a SKODA!!!
    Arrkon's Avatar
    Oct 2010
    1,633
    Am i clutching at straws here guys?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,949
    The correct solution is 4 wheel drive...
    TD5 Land Rover Defender build
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,889
    +1 ^^^
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Arrkon's Avatar
    Oct 2010
    1,633
    Helpful...
    AWD would be an option, if i wanted to transfer everything from mine to a TQS. audio/performance parts/CF trim etc... oh and NEW coilovers.... not really wanting to do all that...
    "Stick a V8 in it!"
    14,949
    There comes a point where you realise theres no point spending more time, effort and money trying to put sticking plasters over the flaws of a FWD car.
    Seems like a big step, but in reality its a weekends work to swap the bits over, and you'll get most of the money back when you sell the old car.
    Aug 2010
    2,889
    You dont own an audi unless its powered by quattro in my eyes !!!
    i had a 1.8 b5 was going to do facelift conversion, wheels, i.c.e etc then came across the TQS and instantly wanted one was going to go scotland for one then actually ended up in southampton and have never looked back even though the car has had its fair share of my wage thats just the beauty of it all lol !!
    Feb 2012
    89
    Get an LSD.
    "Stick a V8 in it!"
    14,949
    and the cost of one of those would easily cover the costs of swapping to a quattro!
    Feb 2012
    89
    It is another option though, and he did say he didn't want to do the quattro thing. Both ways have their respective pros and cons.
    Arrkon's Avatar
    Oct 2010
    1,633
    Quote Originally Posted by dubster67 View Post
    exactly. if it can be a matter of taking a ABS unit from another model, recode and at worst some wiring... it could be a simple (and porentially cheap) option.
    Feb 2012
    89
    if you're confident about doing it, and have all the info eg wiring diagrams then why not give it a try.
    "Stick a V8 in it!"
    14,949
    To achieve what?
    I've only ever heard people complaining about traction control systems getting in the way and being heavy handed.
    Turning the power off just makes you slower.
    You need to increase traction if you want to go faster. That means better tyres, more wheel drive, or a locking diff.
    Feb 2012
    89
    aragorn, I agree with what you're saying re traction, but it sounds like he wants to do it, plus he wants cheapness.
    "Stick a V8 in it!"
    14,949
    And what hes likely to get is a hole in his pocket, hours of his time wasted and a **** outcome.
    Feb 2012
    89
    Probably, but if he cracks it then he's going to be well happy, and it adds to the knowledge base.
    But as said, I'd go with alternatives, because as you said it would take many hours, and I've spent(spending) enough time on my car(s).
    But also, what is the point having all that traction if you've got nothing to exploit it with ie power, and you don't necessarily need power, a sorted chassis is much more satisfying IMO.
    Jun 2011
    Great Melton Norfolk
    1,340
    "You dont own an audi unless its powered by quattro in my eyes !!!"
    This kind of comment is the reason Audi drivers are classed as cocks!
    Probably the best thing the OP could do is take a Driver training course,learning car control etc.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,067
    ASR Retrofit?
    I've got an abs unit from my old car with asr if you want it ?
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    Aug 2010
    2,889
    Quote Originally Posted by gen.heinz guderian View Post
    And they class us as cocks due to the fact that they no we are right when we say drive a quattro you will never look at anything else again !!
    Take a FWD owner put them in to a quattro for a day, then back in there FWD by the end of the day they will be wanting to go and buy/own a quattro !!!
    most of us will agree lol
    Arrkon's Avatar
    Oct 2010
    1,633
    Auto Electrician moved 3yr ago onto a new role as an Automotive Electrical engineer for a uk based OEM following about 10yr exp, should muddle through...
    Dont judge a book by its cover, as most of my work involves development of future models, i have been trained to a grade one advanced driving, under tuition of an ex police instructor
    this is being done more as a "can it be achieved" technical exercise, keeping the grey matter working haha.
    Quote Originally Posted by olds_kool View Post
    Kev, thats great, drop me a PM
    Kev, with respect, its my hole to have... I have spare time to be tinkering on the car... and if its a poor outcome, so be it. worst case is ive wasted a few quid and some time I would no doubt have spent watching the little grey box in the corner of the living room. As previously said, its more of a technical exercise, which will add to the forum knowledge and hell, we all learn best by making mistakes.
    Feb 2012
    89
    Go on my son!
    Jun 2011
    1,340
    Hope its a declared Mod on your insurance then if it is to be driven on the Public road.
    Arrkon's Avatar
    Oct 2010
    1,633
    I will be having a word, of course. However as its an OEM option being added, they are usually fine.
  1. Retrofitting BOSE
    By S3BeemerBeater in forum In-Car Entertainment
    Last Post: 10th July 2006, 09:11
  2. Retrofitting to take flipout keys
    By S3BeemerBeater in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th May 2004, 14:05
  3. ASR Funny on A3T
    By razor in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd October 2003, 09:19
  4. Retrofit Cruise Control
    By Nimo in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2003, 16:08
  5. Retrofit LCD climate control
    By dandy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2003, 11:42
