Volks AutosChris Nott
Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By Ste_Nova
Thread: 2nd Battery
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    2nd Battery
    Maybe its a bit much but with all the kit I got in Audrey that uses power and my paranoia, I started thinking about 2nd batteries or battery backups.
    Two thoughts.
    One was a secondary battery and split charging but I can't think where to put it.
    The second idea was mounting some external terminals in the engine bay and connect them up to a leisure battery when I'm stationary for longs periods of time and want to watch TV, A film or use the projector.
    I think the leisure battery would be a better idea over split chartering. I don't mind carrying a 2nd when I know I'll need, like shows or camping.
    My concern is what damage or problems I might have by connecting a large leisure battery to my battery/car leads.
    Any one got any thoughts?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    place it in the boot
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    That is the obvious idea but not an option for me.
    2,170
    Why not, on the right hand side of the boot where the alarm horm is, you could even run the wires under the car behind the heat shield.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Re: 2nd Battery
    Quote Originally Posted by B5NUT View Post
    It's all full up.
    Right hand side is pump, triangle, hand cleaner, straps and hang grenade.
    Left hand side is TV Tuner, Pi, 12V socket, 240v socket, first aid kit.
    In the middle is my false floor.
    I don't think there is any room in the bay for a 2nd battery.
    I was thinking of mounting a Anderson connector in the bay to connect s leisure battery.
    But need to make sure that it won't damage any thing on car when I connect it.
    2,170
    Only thing I can think of is to buy a larger battery, you may have to do a cut & shut on the standard battery holder for it to fit.
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,642
    bin off the spare wheel? carry tyreweld instead?
    Currently rolling in a SKODA!!!
    CraigG's Avatar
    May 2008
    188
    instead of 2 batteries, just get one massive one from a large diesel engined car (V10 TDI Tourag comes to mind, the battery in that has got to be massive)
    you can then mount it in the original location with abit of modification, or you can relocate the battery to the boot and stick it in the wheel well.
    Imola S4 - Bilstein B6 + Eibach Prokit, Anthracite BBS Pescara 18x7.5"
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Quote Originally Posted by CraigG View Post
    I got the largest battery possible.
    I like my spare wheel, plus I need the spare wheel for my spare fuel tank.
    The V10 TDI has 2 batteries.
    One for the electronics and the 2nd one to start the unit.
    Which is kind of what I'm wanting to do with the leisure battery and Anderson clips.
    CraigG's Avatar
    May 2008
    188
    Quote Originally Posted by ScottB5 View Post
    actually largest possible, or the largest possible without modifying the OE battery mounting point? :D
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    The largest one that would physically fit with out cutting it about and the largest amount of amp hours that had.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,379
    Attaching a second battery is fine, it wont cause any issues whatsoever, HOWEVER, it also wont stop you draining both...
    Sit for long enough at say a car show with all your electrical goodies on, and it will happily run down both batteries and leave you no better off (bar the additional run time) than your current situation.
    Split charging obviously gets round that by disconnecting the starter battery from the load while the engines off. Thus even if you drain the second battery, you can still start the engine from the main one.
    Maybe a small jump pack would be a better idea? At least then you know you've got something to get you started again should you flatten the main battery.
    Also its worth remembering that continually draining your main battery is going to seriously shorten its life.
    The main battery tray takes 3 sizes of battery, however theres a fourth even larger size you can use, by getting a different clamp from the dealer (as the biggest size covers all three holes on the battery tray)
    TD5 Land Rover Defender build
    Arrkon's Avatar
    Oct 2010
    1,642
    2nd Battery
    Use a marine battery switch for simplicity, then just "plug in" the second battery when needed?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Quote Originally Posted by Arrkon View Post
    Cracking idea.
    I like that.
    Thanks mate.
    robbiemac's Avatar
    'S' Button engaged....
    Nov 2012
    733
    My concern is what damage or problems I might .............
    Any one got any thoughts?[/QUOTE]
    With great power comes great responsibility.......
    Apr 2012
    N. Wales, LL22
    1,224
    fit a 2nd and split charge unit, run all your accessories off the 2nd and keep the main for starting
    Mackers likes this.
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
  1. 2nd to 3rd gear change grind/crunch
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th December 2003, 17:20
  2. 2nd AVS Service - How much?
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2003, 15:31
  3. 2nd to 3rd gearchange in S3
    By Adam in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th May 2003, 23:41
  4. Audi-Sport Trackday Castle Coombe 2nd April 2003
    By johneroberts in forum Major UK Events
    Last Post: 26th March 2003, 18:25
  5. Battery Voltage
    By Naresh in forum In-Car Entertainment
    Last Post: 21st January 2003, 19:31
