Sky InsuranceAH Fabrications
Results 1 to 14 of 14
Thread: loud ticking??
    Oct 2012
    Manchester
    24
    loud ticking??
    Hey guys i got a problem with my car there's a annoying ticking coming from my engine when it starts for a few seconds then dies down and goes it returns when the engine gets up to temp and its quite loud i changed the cam chain and tensioner thinking it was that but no luck im stumped on what it could be?? Any thoughts thanks
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    oil pump?
    Have you checked the pressure?
    TD5 Land Rover Defender build
    Oct 2012
    Manchester
    24
    Ye its got a good oil pressure. I was thinking of giving it a oil change see if that would do anything
    Reload's Avatar
    Bird is the Word!
    Jul 2010
    Midlands
    367
    A bomb?
    S3 8P2 Ice Silver, RNS-E, Bluetooth, iPod connection, Adaptive xenons, black styling pack, sunroof, privacy glass
    Mods since owned: Milltek Resonated TBE, Neuspeed P-Flo, Loba HPFP, Sachs Clutch with Loba SMF, Unicorn Motor Developments custom remap, brakes + suspension upgrades, LEDs internal and external, more interior kit
    Jun 2011
    Great Melton Norfolk
    1,356
    how was the chain for the vvt at the back of engine?
    Oct 2012
    Manchester
    24
    The chain looked fine so did the tensioner its all working sweet apart from that noise
    Jun 2011
    1,356
    Try an oil change / check oil pick up pipe in Sump isnt getting blocked with sludge.
    Oct 2012
    Manchester
    24
    Ok ill try that thanks for your input guys
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Give the car a good flush with a 50/50 mix of old oil and diesel run it up to temp preferrably drive it then drop oil and change oil & filter get the 'bigger' oil filter as well. I run the K&N HP-3001 on my 3rd one now as i did it last week never had trouble with them !!
    Oct 2012
    Manchester
    24
    How do u mean 50/50 how much 1L or more and ill get the bigger filter then if its better.
    Jan 2013
    59
    Could it possibly be the purge valve on top of the airbox that's ticking away? They can be quite loud at times.
    Oct 2012
    Manchester
    24
    No i know that ticks but this is so loud .this morning on the way to work the oil pressure warning light comes on i already checked the oil and that's all fine ?
    Aug 2010
    3,138
    Pick up is blocked get that sump off asap id be putting a new pump in whilst the sump is off rather than just cleaning the pick up !!!
    "Stick a V8 in it!"
    15,385
    oil pump?
    As i said away back at the start, have you checked the pressure?
    The fact the lights come on means you havent, and understand that light means "STOP DRIVING NOW". If you've continued to drive it around knowing theres an oil pressure issue, you run a very high risk of scrapping the engine or the turbo or both.
  1. Loud ticking noise
    By MrLapou in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd April 2012, 11:39
  2. afn tdi loud ticking noise i think from n75
    By pirate in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th August 2011, 01:12
  3. Loud ticking noise from Unit behind O/S/F headlamp
    By faisal in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2005, 13:22
  4. Consistent TICKING noise? Please help!
    By 97AUDIA418TQ in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd October 2003, 22:04
  5. Ticking noise on the left
    By edwin98 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th June 2003, 10:24
