Volks AutosEM Tuning
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    158
    Brand new battery, battery light on with cold start, blip accel and it goes away.
    Hi guys I have tried to search for this symptom, essentially like the title says.
    Any ideas, alternator is def putting out the 13.8 volts.
    Jonny
    (1996 B5 1.9 TDI 90bhp 1Z Engine)
    1996 A4 B5
    1.9TDI SE
    Gone but not forgotten
    Audi A4 2.5TDI Quattro
    Skoda Octavia 1.9SDI (Wont be missed lol)
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,870
    Battery should charge around 14.3/14.4 with no consumer load whats the battery voltage not running after 10 mins ?? The battery you have may look brand new but may have been sat on a shelf and in need of a 24 hour trickle charge battery should read around 12.6/12.7 new if its under 12.2 try a trickle charge see what that does also hook a multimeter up to the battery see what voltage you have with it at idle then raise it to 2k see what happens !!
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Craigs S4 does this very same thing.
    Start it up and the battery light is on and the voltmeter reads 12v. If you dont touch the throttle and leave it idling it stays at 12v and the light stays on. Give the throttle a poke to blip the revs and it jumps up to 14v and the light goes out, and it then charges fine even when idling from then on.
    Its been like that for a year, hes been ignoring it as alternator is a pig to get at and is expensive.
    Interestingly, it started after we put the engine in another car, so i had a bit of a feeling that it was a wiring issue, but i cant see anything wrong.
    TD5 Land Rover Defender build
    Jan 2011
    Aberdeenshire
    628
    Mrs PaulFs Avant 2.5TDi does similar - although if you leave it idling for a while, it also comes up. The light isn't on, just a lower charge.
    That's with different batteries and different alternators too.
    It may just be an Audi 'thing' - although I suspect a higher than normal resistance earth or contactor somewhere.
    1999 A4 B5 1.9 TDi FWD Saloon, Green
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine)
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    "Stick a V8 in it!"
    14,900
    I wouldnt say its normal, None of mine do it, and craigs didnt used to until we swapped the engine.
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    577
    Dunno if this is of any use but my old 90 did this exact same thing and it was the voltage regulator on the alternator. On those alternators you could change the v r with the brushes for about 12 quid. I don't know if you can do that with these
    2000 1.8t quattro Sport totally standard (ish)
  1. Replies: 1
    Last Post: 9th June 2011, 14:32
  2. Fitting a new a4 battery - please help!!!
    By eddie13 in forum General Technical / How To
    Last Post: 2nd February 2009, 13:29
  3. Fitting a new a4 battery - please help!!!
    By eddie13 in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd January 2009, 22:31
  4. For Sale: Brand new 8.5x19" ADR M-Sport with tyres
    By ultramodz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th June 2008, 19:31
  5. For Sale: Brand new 8.5x19" ADR M-Sport with tyres
    By ultramodz in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th June 2008, 13:29
Tags for this Thread
