Results 1 to 10 of 10
    Jan 2013
    Norwich
    127
    Where does the OE sub live on a B5 Avant...?
    As in the title, where does the original Nokia sub woofer live on the B5 Avant's?
    Thanks.
    '92 VW Corrado 20vt
    '98 Audi A4 Avant TDi 110 - EGR delete...
    '08 BMW 320d Edition M-Sport Touring
    'You screw up just this much, you'll be flying a cargo plane full of rubber dog sh*t out of Hong Kong'
    Sep 2011
    Sunny Bangor. N.Wales.
    288
    behind the boot trim on the left of the boot (opposite the fuel cap), if you take off the access panel, and look in the hole and towards the front og the car, the black plastic it the "BOX" that it is in.
    2000, A4 2.5Tdi Quattro.
    Tinted, 3600WATTSLoud
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,018
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Jan 2013
    Norwich
    127
    Quote Originally Posted by ScottB5 View Post
    Cheers for the pic mate, now going to have a look to see if it's actually there, CD changer wasn't so I'm guessing this won't be either!?
    '92 VW Corrado 20vt
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    early cars didnt have it, but i think yours should seeing as its a '98.
    TD5 Land Rover Defender build
    Jan 2013
    Norwich
    127
    I'll have a nosy in there anyway, I'm not 100% what my car should have tbh as it was a run out of the PFL on an S plate.
    '92 VW Corrado 20vt
    Biodiesel Purrrr
    Jun 2011
    London
    150
    to be fair it's hardly a sub anyway, just a bit of mid-bass gets it sounding a bit nasty... [it's made of tupperware plastic]
    you can see the side / top section just removing the pass. side cubbyhole cover without taling off the whole side panel.
    TDi Biodiesel sippin' A4 Avant - EGR blanked
    "Cars are good but Jeremy Clarkson is a dick."
    Jan 2013
    Norwich
    127
    Cheers peeps for responses, just checked and to my surprise its still there!
    My next question, would a Bose sub from the S4/RS4 slot straight in?
    '92 VW Corrado 20vt
    2,176
    No. With the standard setup the AMP if you can call it that feeds the rears speakers, and the head unit does the front speakers. With the Bose setup the AMP feeds all the speakers, so you would have to run the front speaker wires from the brown connector to the rear, and you would also need to run 2 wires for front left/right audio out to the AMP. Your also going to have to cut off the plug going into the current amp and and fit a new connect compatible with the Bose AMP.
    You should also replace the speakers as the Bose speakers are 2ohm, and the standard speakers are 4ohm, they would work with the 4ohm speakers but it's best if you have the correct stup.
    "Stick a V8 in it!"
    15,385
    Bose is ****e anyway, buy a proper amplifier and proper subwoofer.
    You can pick up decent quality kit on ebay for buttons.
  1. Cruise Control Retrofit - Where does the Repair wire go!
    By jsh712p in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th August 2009, 10:57
  2. where does the rear washer line run on an avant?
    By jcb in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd January 2009, 23:59
  3. where does the factory sub plug in in my a3??? RACKING MY BRAIN BIG TIME
    By samthomas33 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2008, 11:34
  4. where does the auto gearbox oil go?
    By shufti in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 23rd July 2007, 15:40
  5. where does the clutch cable attach to the engine
    By nick1973 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th December 2006, 20:43
