Monster MotorsportChris Nott
Results 1 to 16 of 16
Thread: next step
    Jan 2013
    7
    next step
    ok never ceen one to drive a standard motor for more than 5 minutes, whats the next level for my b5 s4? remap? injectors and turbos changed? what other turbos bolt directly on and what power would they give me, i still want a reliable car though
    Jan 2013
    I would recommend reprogramming and turbos K04and also change injectors
    Jan 2013
    7
    Quote Originally Posted by Danielrm View Post
    what model are they from?
    Jan 2013
    a friend has a 2000 S4 and made those changes and it is a beast
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,934
    You need to set yourself a goal and work towards it, rather than just blundering around changing things at random.
    The standard turbos max out around 340-350hp. They'll only get there with a raft of additional modifications though, such as a full exhaust, bigger downpipes (either RS4 with gutted precats or aftermarket), intercooler and a good customised remap.
    A stock car with a generic remap will see you to around 300hp. Exhaust and downpipes might see 320-330 but heat starts to become an issue with the stock coolers.
    If you want to go further the next step would be to install the K04 turbos from an RS4. This is a big expense though, the turbos are about 2k new, or you can collect used sets for around 600-700. The engine needs to come out to fit them, so your talking best part of a grand in labour, and given that, its almost always advised to have and used turbo refurbished before fitting. you'll also need some additional pipework to fit them which will run you a few hundred quid.
    With those fitted, you have scope for upto about 500hp with the right bolt ons. The exhaust, downpipes and intercooler mentioned above will all fit the K04 turbos just fine. The stock injectors wont do much more than about 350hp safely, so you'll need to upgrade those. People suggest doing the fuel pump as well if going past 400hp. You can use RS4 parts for both the injectors and pump, or go for aftermarket parts (my preferred option)
    TD5 Land Rover Defender build
    Sep 2006
    32
    I have just bought an S4 with K04 Turbos on. Is there an easy way to check if injectors have been changed? Anyone have part numbers for RS4 ones to hand if I need to order them?
    Tom Everett ======================
    Audi S4 - K04 Turbos, MRC Remap, RS4 Brakes, 19" BBS, Still finding out what else has been done....
    Toyota MR2 Turbo For Sale
    Audi S3 Sold
    Impreza P1 Sold
    Seat Leon Cupra R Sold
    Oct 2008
    Glasgow
    430
    Quote Originally Posted by tominski View Post
    If you are running much more than 350-380 then you wont be running stock s4 injectors. RS4 injectors are short (48MM), S4 injectors are long (60mm) so it will be obvious to see which you are running. If you are pushing past 450bhp then i would recommend upgrading to deka 630cc injectors which will support 650bhp+ If you are running a standard s/rs4 fuel pump then i would be upgrading to a bosch 044 pump.
    Oct 2008
    Glasgow
    430
    Quote Originally Posted by T5frankie View Post
    If looking to go bigger turnos then K04 (RS4 turbos) is the most common upgrade. This will see you into the mid 400's easily depending on the supporting mods.
    Things to change would be -
    Injectors
    fuel pump
    manifolds (if using pre facelift)
    downpipes & exhaust
    Intercoolers
    Intake pipes
    Sep 2006
    32
    Thanks for info and sorry to hijack thread a bit..
    Any more info on these as mine is PreFace lift
    Intake pipes
    Audi S3 Sold
    Impreza P1 Sold
    Oct 2008
    Glasgow
    430
    Any more info on these as mine if PreFace lift
    Intake pipes
    pre facelift manifolds are prone to the inner skin breaking up (they rattle) You can source facelift/rs4 manifolds for around £100.
    The intake pipes on the s4 are not the correct size if going to k04 turbos. You can source rs4 intake pipes for around £200. These are a direct fit to the car and turbo.
    Sep 2006
    32
    Thanks, I'll have a proper look. I have seen It has samco style hose bits where the recirc valves are connected. I've looked at some pictures and the 'y' pipe across the top of engine looks different on RS4 to S4, that right? Do they run the same size MAF too?
    Audi S3 Sold
    Impreza P1 Sold
    Oct 2008
    Glasgow
    430
    Any questions just drop me a pm.
    Yeah the rs4 runs a different maf & diameter maf housing.
    Sep 2006
    32
    Thanks, it that worth a change?
    PS - your inbox is full
    Audi S3 Sold
    Impreza P1 Sold
    "Stick a V8 in it!"
    14,934
    TBH most PFL manifolds were changed under warranty years ago, i very much doubt you'll find many cars running around today with the faulty PFL manifolds.
    Oct 2008
    Glasgow
    430
    If going for more power then i would recommend changing it.
    My bad :-) Try again or drop me an email - sales@wotmotorsport.com
    Sep 2006
    32
    Thanks, Dropped you an email
    Audi S3 Sold
    Impreza P1 Sold
  1. A3 on 18's, Next Step Lowering, But How Much???
    By RyanGolfGTTDi in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st April 2009, 23:21
  2. WHAT MY NEXT STEP
    By CMD in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th February 2009, 17:50
  3. Next Steps for tuning an A6 1.8T
    By Blueone in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 1st September 2007, 06:45
  4. RS4 project next steps.
    By docurley in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th May 2006, 16:51
  5. Next Step
    By csleee in forum TT/TT-S/TT-RS Forum
    Last Post: 4th May 2004, 10:23
