Chris NottMonster Motorsport
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    sat nav or pda tom tom questions
    hi all i have a b5 a4 with a symphony cd (double din type) so im think the sat nat plus unit could just slot in ,
    what extra wiring would i need to get it working ?
    is there a website that shows how this is done
    or should i go for the pda type tom tom
    looking for pros and cons
    please
    imported_CurryMilkShake
    Re: sat nav or pda tom tom questions
    Personally would prefer the built in unit, looks grreat in the dash, very neat.. there's been loads of threads here on exactly this subject if you do a search, craigyb being the man i think you need to speak with!! lots of pics too
    However, I dont have it in my dash, and do have a tomtom.. very neat, easy, arguably much cheaper and certainly less hassle than upgrading to a built in one, works extremely well and can be swapped to the other car as required..
    so for me, the only reason for the satnav plus would be that 'original equipment' look.. is it worth the time money and hassle? only YOU can decide that, it wasnt for me..
    not sure about resale value either, others best placed to comment on that
    with Tomtom, you'll be up and running 10mins after you get home from the shop! (or at least after youve charged it!) just doesnt look as neat.
    imported_VaulterTim
    SatNav Plus will slot straight into a double-din cage, you just have to make sure you get the correct revision for your year of car and I can't remember which is which off the top of my head. Some have provision for CAN bus which enables it in your DIS, some don't (older models at a guess...)
    As already suggested, do a search because it has been covered quite a few times already [img]/ubbthreads/images/graemlins/smile.gif[/img]
    I considered doing this myself when I saw a cheap SatNav Plus unit on German e-bay but when I realised the install meant swapping my whole centre console (because I have a single-din stereo), the cage, the ashtray and the corresponding Climate Control unit... you get my meaning [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    T
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    yea i do likethe original look
    ill do a search for craig
    thanks
    any other opinoins welcome
    cheers
